ALT pulley removal/install. HOW?????????? #72076
06/12/08 01:47 PM
06/12/08 01:47 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
I need to remove the pulley from my alt, in order to install a March serpentine pulley.
First, how in the heck do you get it off?? I have a two arm puller, and it would not move at all, even after heating the pulley a bit. (carefully)
Second, if I ever get it off, how do I go about putting the billet pulley on without damaging it? Put it in boiling water for a while and then gently tap it on?
Need some guidance here guys. I called a local auto electric place here, that rebuilds starters and alternators, and they don't have a puller .
codfish
Re: ALT pulley removal/install. HOW?????????? [Re: codfish] #72077
06/12/08 01:58 PM
06/12/08 01:58 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
To remove the pulley, simply remove the nut and lock washer. There should be no need for a puller. If it doesn't just come off with the nut removed, you've got a problem and may need a new alternator.
Re: ALT pulley removal/install. HOW?????????? [Re: dodgeram440] #72078
06/12/08 02:03 PM
06/12/08 02:03 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
There is no nut holding the pulley on. Just an interference fit.
codfish
Re: ALT pulley removal/install. HOW?????????? [Re: codfish] #72079
06/12/08 02:25 PM
06/12/08 02:25 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
My bad. I thought all alternators had bolt on pullies. I couldn't remember ever seeing one that wasn't bolted on. So I went out and checked the one on my truck and the one for my 440, and darned if you aren't right. Sorry, don't know what to tell you know.
Re: ALT pulley removal/install. HOW?????????? [Re: codfish] #72080
06/12/08 02:39 PM
06/12/08 02:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you need a puller to get it off and i'm not sure how you get the march pulley back on , it should be a press fit and you need to take apart the alt to support the back of the shaft you are pressing the pulley onto ???
Re: ALT pulley removal/install. HOW?????????? [Re: codfish] #72081
06/12/08 02:40 PM
06/12/08 02:40 PM
Baltimore, MD
MadMax58 Offline
MadMax58  Offline
Baltimore, MD
The alternator pulley on Mopars is pressed on. You would need the same type of tool that is used to remove a power steering pulley that is most of the time also pressed on. I believe that the whole alternator has to come apart to press the new pulley on to what I think is called the stator. Any shop that rebuilds alternators would be able to help you with this type of job.
Re: ALT pulley removal/install. HOW?????????? [Re: MadMax58] #72082
06/12/08 03:25 PM
06/12/08 03:25 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
something i always hated about the mopaR ALTERNATOR.
i heard the toyota mini replacement is bolt on.
Re: ALT pulley removal/install. HOW?????????? [Re: mark7171] #72083
06/12/08 09:30 PM
06/12/08 09:30 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Correct you need to split the case and have the pulley pressed on.It usually dosent take a lot to get them on.Really a simple job if you take some time the first time you do it.You can rent a puller from most parts stora and get your money back when you return it.Rocky
Chrysler Firepower
Re: ALT pulley removal/install. HOW?????????? [Re: therocks] #72084
06/12/08 10:13 PM
06/12/08 10:13 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
You can buy a pulley puller on eBay for about $15. I did last year and it has already paid for itself.
When you go to the salvage yard and need to remove a pulley (alternator, power steering pump, etc.) to fit your application, you have your own puller.
Re: ALT pulley removal/install. HOW?????????? [Re: therocks] #72085
06/12/08 10:14 PM
06/12/08 10:14 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Yeah make sure you split the alternator before pulling. You can bend the heck out of the pulley with a regular gear puller if you're not careful. DAMHIK
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: ALT pulley removal/install. HOW?????????? [Re: wingman] #72086
06/12/08 10:28 PM
06/12/08 10:28 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Take it to the altenator shop and hand the man $10. That's what I did it worked great.
Re: ALT pulley removal/install. HOW?????????? [Re: moparpollack] #72087
06/12/08 11:16 PM
06/12/08 11:16 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
I would, but as in the original post, they don't have anything to do it , otherwise I definitely would have.
codfish
Re: ALT pulley removal/install. HOW?????????? [Re: codfish] #72088
06/12/08 11:33 PM
06/12/08 11:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
They are BSing you. If they build alts for a living they have the puller. They may not want to pull yours off but they have the equipment.
Re: ALT pulley removal/install. HOW?????????? [Re: stumpy] #72089
06/14/08 12:02 AM
06/14/08 12:02 AM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
I'm pretty sure your right Stumpy, but what do you do? . Can't force them to do it. And they're the only game in town.
Anyhow, I broke out the sawzall after breaking a three arm pulley I got through a "loan-a-tool" program. (good thing it had a lifetime warranty ). Cut the pulley through the center of the "V-groove", and then used a two arm puller to pull it off. I can't believe how hard this was to come off. Alt is only two years old.
Anyhow, all is good again,
thanks guys
gary
Re: ALT pulley removal/install. HOW?????????? [Re: codfish] #72090
06/15/08 12:07 AM
06/15/08 12:07 AM
ILLINOIS
V
volaredon Online content
volaredon  Online Content
V
ILLINOIS
2 things; 1st, is this a 100 A alt we are talking about? If so the P/S pulley tool wont work. also, even the mere suggestion of a Toyota ANYTHING on any of my Mopars is a slap in the face!
