ALT pulley removal/install. HOW??????????
#72076
06/12/08 01:47 PM
06/12/08 01:47 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
I need to remove the pulley from my alt, in order to install a March serpentine pulley. First, how in the heck do you get it off?? I have a two arm puller, and it would not move at all, even after heating the pulley a bit. (carefully) Second, if I ever get it off, how do I go about putting the billet pulley on without damaging it? Put it in boiling water for a while and then gently tap it on? Need some guidance here guys. I called a local auto electric place here, that rebuilds starters and alternators, and they don't have a puller . codfish
Re: ALT pulley removal/install. HOW??????????
[Re: codfish]
#72081
06/12/08 02:40 PM
06/12/08 02:40 PM
Posts: 105 Baltimore, MD
MadMax58
Baltimore, MD
The alternator pulley on Mopars is pressed on. You would need the same type of tool that is used to remove a power steering pulley that is most of the time also pressed on. I believe that the whole alternator has to come apart to press the new pulley on to what I think is called the stator. Any shop that rebuilds alternators would be able to help you with this type of job.
[Re: mark7171]
#72083
06/12/08 09:30 PM
06/12/08 09:30 PM
Posts: 21,050 Niles , Ohio
therocks
Niles , Ohio
Correct you need to split the case and have the pulley pressed on.It usually dosent take a lot to get them on.Really a simple job if you take some time the first time you do it.You can rent a puller from most parts stora and get your money back when you return it.Rocky
Chrysler Firepower
[Re: wingman]
#72086
06/12/08 10:28 PM
06/12/08 10:28 PM
moparpollack
Lil Herman
Lil Herman
85086
Take it to the altenator shop and hand the man $10. That's what I did it worked great.
[Re: moparpollack]
#72087
06/12/08 11:16 PM
06/12/08 11:16 PM
codfish
Newfoundland
I would, but as in the original post, they don't have anything to do it , otherwise I definitely would have. codfish
[Re: stumpy]
#72089
06/14/08 12:02 AM
06/14/08 12:02 AM
codfish
Newfoundland
They are BSing you. If they build alts for a living they have the puller. They may not want to pull yours off but they have the equipment.
I'm pretty sure your right Stumpy, but what do you do? . Can't force them to do it. And they're the only game in town.
Anyhow, I broke out the sawzall after breaking a three arm pulley I got through a "loan-a-tool" program. (good thing it had a lifetime warranty ). Cut the pulley through the center of the "V-groove", and then used a two arm puller to pull it off. I can't believe how hard this was to come off. Alt is only two years old.
Anyhow, all is good again,
thanks guys gary
