Page 1 of 4 1 2 3 4
MP .590 cam info UPDATE WITH RESULTS #720108
06/09/10 09:42 PM
06/09/10 09:42 PM
MD
Kevins493 Offline OP
MD
I have a MP .590 cam but it came with no information as to where it should be degreed in. I know there are two versions; my part number ends with 663 (no suffix).
Re: MP .590 cam info [Re: Kevins493] #720109
06/09/10 09:55 PM
06/09/10 09:55 PM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
Great cam if matched properly. Don't let anybody tell ya otherwise.
Mopar Performance #312-P4120663
Purple Shaft Cam & Lifter Kit
Adv. Duration: .312°/312°
Dur. @ .050'': 265°/265°
Lift: .590''/.590''
Centerline: 106°
Basic RPM: 3400-6900 RPM
Bolt Pattern: 3-Bolt
Re: MP .590 cam info [Re: 10sec440] #720110
06/09/10 09:58 PM
06/09/10 09:58 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Thanks 10Sec440!
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: MP .590 cam info [Re: Kevins493] #720111
06/09/10 10:01 PM
06/09/10 10:01 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
4120663 312 590 106 RC 104 BIG B 4120657 312 590 106 rc 104 SMALL B
Re: MP .590 cam info [Re: cbarracuda] #720112
06/09/10 10:06 PM
06/09/10 10:06 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
We put the one in my buddies up to 100 after it was a little lazy on launch at 104. 446 with eddie heads and 4400 stall MP tunnelram two 700 DP's
Re: MP .590 cam info [Re: Dads426] #720113
06/09/10 10:12 PM
06/09/10 10:12 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Thanks 10Sec440!
With 10 Sec 440!, Great Cam!
It will perform just as well against the latest/newest modern design cams in most cases of similer size.
Its actual true .050 lift duration dimensions are around 271 @.050 vs the advertized 265 @.050 as measured by Dwayne Porter, Me and a few others around here.
Most users of it like it installed at around a 99*to 102* ICL if intake valve clearence allows.
Great cam , Mike
Re: MP .590 cam info [Re: Kevins493] #720114
06/09/10 10:40 PM
06/09/10 10:40 PM
Texas, USA
68cuda2003 Offline
68cuda2003  Offline
Texas, USA
I was in the same situation you are in. I telephoned mopar performance and the guy emailed me the cam card. It was simple. Hope this helps.
Re: MP .590 cam info [Re: 10sec440] #720115
06/09/10 11:13 PM
06/09/10 11:13 PM
ill
dennismopar73 Offline
ill
dont like em
had 1 killed it self in 5 passes
went with racer brown after that wouldnt look back
Re: MP .590 cam info [Re: 68cuda2003] #720116
06/09/10 11:19 PM
06/09/10 11:19 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I installed it 2* advanced (from straight up) and found I had too much torque, retarded it 4* (2* from straight up) and it calmed the car down, but really didn't slow it down much.
Brian
Re: MP .590 cam info [Re: '72CudaRacer] #720117
06/10/10 12:43 AM
06/10/10 12:43 AM
MD
MD
Thanks everyone!
Re: MP .590 cam info [Re: Kevins493] #720118
06/10/10 01:09 AM
06/10/10 01:09 AM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
Not sure if this helps but I believe the old Direct Connection spec called for it to be installed at 104.
BTW: My zero deck, flat piston, .030 over 440 w/915 closed chamber ported iron heads, and that cam made 565 HP @ 6200 and 520 ft/lbs @ 4900 rpm with an M1 single plane and 850HP. I installed mine at 104. My compression is 11.25:1
Don't know if this helps......but.........
I like that cam................
Curator at Adams County Speed Shop
Re: MP .590 cam info [Re: 340man4ever] #720119
06/10/10 07:58 AM
06/10/10 07:58 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Would this cam still be pump gas friendly (93 octane) with aluminum heads and say 11 to 1 compression? Would it be worth it to use this cam in a 493 at that point for a street/strip car?
Seems like it would not be too difficult to build a 600HP 493 with MCH Eddy RPM heads and a Holley Street Dominator and thei cam? Flat tops? Maybe? Just bench racing....
Michael
Re: MP .590 cam info [Re: SILVER67] #720120
06/10/10 08:03 AM
06/10/10 08:03 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I run it in a 10/5.1cr w aluminum heads street car, I am happy with it. Runs fine on pump gas in a 470 low deck.
Re: MP .590 cam info [Re: SILVER67] #720121
06/10/10 09:25 AM
06/10/10 09:25 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Michael
That sounds almost exactly like the combination I am planning for the 67 R/T I just picked up,....have you been snooping around in my shop?
Re: MP .590 cam info [Re: Kevins493] #720122
06/10/10 09:58 AM
06/10/10 09:58 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Hey Kev, Big Bill was running 10.80's with that cam in his old 440 dart. Everybody seems to like it.
Coming soon!!!!
Re: MP .590 cam info [Re: Dunnuck Racing] #720123
06/10/10 10:04 AM
06/10/10 10:04 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
HA HA , not entirely snooping Keith. A couple of years ago you sent me a used .590 in great shape, I just had to pay the shipping. I am trying to build a combination in my mind that I can use it now. The .590 seems to be a cam that will get a 493 close to the 600HP mark with MCH stage I ported Eddy RPM's.... Or at least I am hoping.
Like to get my '67 R/T in the 11's.....
Michael
Re: MP .590 cam info [Re: SILVER67] #720124
06/10/10 10:25 AM
06/10/10 10:25 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Michael
you should be well into the 11's w/ that combo, You could probably get into the 11's w/ a 557.
Re: MP .590 cam info [Re: Mr.Yuck] #720125
06/10/10 11:25 AM
06/10/10 11:25 AM
City of Champions
P
Prostock Offline
Prostock  Offline
P
City of Champions
Michael
I have that cam with unported 88cc eddy heads and just a .030 over 440 and I am in the mid 11's with a 4.10 gear. Runs fine on pump gas too.
Re: MP .590 cam info [Re: Mr.Yuck] #720126
06/10/10 12:05 PM
06/10/10 12:05 PM
MD
MD
Michael
Ron (383man) runs 11.4? with the .557 cam in a 3700lb pump gas street car through the mufflers.
Re: MP .590 cam info [Re: Kevins493] #720127
06/10/10 12:25 PM
06/10/10 12:25 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
I think the 3.23 gears are going to slow me down a bit.... Wondering how the .590 will like the 3.23's?
I do have a good 9 1/2 Dynamic (currently stalls a tad over 3000 in the .090 in the hole 440 I have with a Comp 470H) and a low first gear if that helps...
Michael
Page 1 of 4 1 2 3 4
