Re: How do you fill fuel bowl on six pack pre-start?
[Re: RodStRace]
#719191
06/09/10 07:12 AM
06/09/10 07:12 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Aren't the outboards open slightly and also have a small amount of fuel pulling at idle to keep the fuel fresh? That would affect idle quality. I'd prime them all and make sure the needles and seats work on the all at that first fire-up.
The outboards should have no effect on idle. They should be shut. This is what I was told by a few 6-pack guys. You can prime the outboards but they will fill up in no time. This is how I did my engine with the new cam and last year when I bolted the 6-pack on. We didn't even hook up the outboard linkage until we had a good idle, timing was set and a good 14lbs of vacuum. Seems to work. I'll let you know how they pull as soon as I get my steeering column adaptor ![](/ubbthreads/images/graemlins/panic.gif)
[Re: Mr.Yuck]
#719196
06/09/10 10:30 PM
06/09/10 10:30 PM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
FYI , outboards have a little lot to do with idle .. You must have misunderstood the six pack gurus .. You can tune the carbs without the linkage connected ( dont know why you would want to )But dont be misled , maybe your brand new carbs out of the box may have factory plugs in the idle air mixture screws in the base , they are for idle .. Promax sells custom plates that enable you to tune the carbs without pulling the center off .. You MIGHT be able to tune a small cam engine without tuning the outboards (not sure) , BUT you'll eventually pull the factory plugs out .. So prime the carbs if you need to but theres awesome links on this website when it comes time to tuning , Be careful who you get advice from .. http://www.mopar1.us/6barreltips.htmlhttp://www.moparts.org/Tech/Archive/fuel/7.html
[Re: Dave Watt]
#719199
06/10/10 11:18 AM
06/10/10 11:18 AM
Mr.Yuck
Brookeville, Md
An old gear lube bottle turned upside down with the bottom cut off makes a good carburetor funnel for filling the bowl. The pointed little cap on top will go right in the vent tube.
dude that's a good idea.
[Re: ZIPPY]
#719201
06/10/10 11:48 AM
06/10/10 11:48 AM
Challenger 1
Cincinnati, Ohio
Electric fuel pump works well.
You smart allic... ![](/ubbthreads/images/graemlins/thumbs.gif)
I just spun my motors over a few times and it started right up when it was new with a mech pump.
