How do you fill fuel bowl on six pack pre-start? #719184
06/08/10 02:03 PM
06/08/10 02:03 PM
State of Flux
Dodge Don Offline OP
State of Flux
Probably a silly question however I'm not at home and can't look at the carbs or check the FSM right now.
So how do you pre-fill the fuel bowl on a six pack? Assuming I only have to do the center carb to get her started. Engine already broken in and dynod but this would be he first start in awhile. Do I fill through the sight plug?
Thanks guys.
Re: How do you fill fuel bowl on six pack pre-start? [Re: Dodge Don] #719185
06/08/10 02:13 PM
06/08/10 02:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you can do it thru the bowl vent tube , site plug out so you don't overfill it
Re: How do you fill fuel bowl on six pack pre-start? [Re: JohnRR] #719186
06/08/10 02:36 PM
06/08/10 02:36 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I fill it the vent right down the vent. I use a large syringe.
Coming soon!!!!
Re: How do you fill fuel bowl on six pack pre-start? [Re: Mr.Yuck] #719187
06/08/10 02:50 PM
06/08/10 02:50 PM
State of Flux
State of Flux
Ok...out of curiosity where is the vent tube on the center carb? I think I recall them on the outboards but not sure about the center.
Re: How do you fill fuel bowl on six pack pre-start? [Re: Dodge Don] #719188
06/08/10 04:41 PM
06/08/10 04:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
sticking up from the choke horn
Re: How do you fill fuel bowl on six pack pre-start? [Re: JohnRR] #719189
06/08/10 09:37 PM
06/08/10 09:37 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
the hole in the middle of the carb...right here. and no need to fil the out boards. I'd unhook them until you get the idle speed and vacuum you like.
Re: How do you fill fuel bowl on six pack pre-start? [Re: Mr.Yuck] #719190
06/09/10 12:08 AM
06/09/10 12:08 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Aren't the outboards open slightly and also have a small amount of fuel pulling at idle to keep the fuel fresh? That would affect idle quality. I'd prime them all and make sure the needles and seats work on the all at that first fire-up.
Re: How do you fill fuel bowl on six pack pre-start? [Re: RodStRace] #719191
06/09/10 07:12 AM
06/09/10 07:12 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The outboards should have no effect on idle. They should be shut. This is what I was told by a few 6-pack guys. You can prime the outboards but they will fill up in no time. This is how I did my engine with the new cam and last year when I bolted the 6-pack on. We didn't even hook up the outboard linkage until we had a good idle, timing was set and a good 14lbs of vacuum. Seems to work. I'll let you know how they pull as soon as I get my steeering column adaptor
Re: How do you fill fuel bowl on six pack pre-start? [Re: Mr.Yuck] #719192
06/09/10 07:24 PM
06/09/10 07:24 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
Do you have small kids?
If so, use the squeezeball thing that you clean their nose with.
I call it a booger-snuffer!
just pour some gas in a cup then suck it up with the booger-snuffer and squeeze it into the fuel bowl vent,works perfect!!
Re: How do you fill fuel bowl on six pack pre-start? [Re: jcastle1] #719193
06/09/10 07:49 PM
06/09/10 07:49 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
The outboards have no effect on the idle? Really?
Re: How do you fill fuel bowl on six pack pre-start? [Re: scatpacktom] #719194
06/09/10 09:44 PM
06/09/10 09:44 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
hey this is my frist one 6-pack). And both people that have helped have had plenty of 6-pack knowledge and 3800+lbs cars that run 11's, so I trust them. They both have had multiple nice running six-pack cars and both told me to do it this way. DO they have an effect? maybe but they SHOULD not be open at all when the car is in P and the idle is at 800 or so. That'd be like your secondaries on a 4bbl being open a tad. I can see if you have some BIG duration choppy cam but for a mild build or newer cam grind the outboards shouldn't need to be cracked to get a good idle. I believe I even read that on a post here last year about tuning a 6-pack. I read where guys drive 50+ miles to the track w/o the outboards even hooked up for milage, then hook them up then run. It works for me.
Re: How do you fill fuel bowl on six pack pre-start? [Re: Mr.Yuck] #719195
06/09/10 10:17 PM
06/09/10 10:17 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
outboard carbs, when closed, contribute to the idle mixture. there are idle circuts in both outboards.
Re: How do you fill fuel bowl on six pack pre-start? [Re: Mr.Yuck] #719196
06/09/10 10:30 PM
06/09/10 10:30 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
FYI , outboards have a little lot to do with idle .. You must have misunderstood the six pack gurus .. You can tune the carbs without the linkage connected ( dont know why you would want to )But
dont be misled , maybe your brand new carbs out of the box may have factory plugs in the idle air mixture screws in the base , they are for idle ..
Promax sells custom plates that enable you to tune the carbs without pulling the center off ..
You MIGHT be able to tune a small cam engine without tuning the outboards (not sure) , BUT you'll eventually pull the factory plugs out ..
So prime the carbs if you need to but theres awesome links on this website when it comes time to tuning , Be careful who you get advice from ..
http://www.mopar1.us/6barreltips.html
http://www.moparts.org/Tech/Archive/fuel/7.html
Re: How do you fill fuel bowl on six pack pre-start? [Re: sogtx] #719197
06/10/10 10:24 AM
06/10/10 10:24 AM
State of Flux
State of Flux
Thanks guys. Didn't expect it to become a debate but hey that is Moparts.
I have a small syringe for kids medicine I can use.....but the Booger Snuffer is on stand-by
Re: How do you fill fuel bowl on six pack pre-start? [Re: Dodge Don] #719198
06/10/10 11:13 AM
06/10/10 11:13 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
An old gear lube bottle turned upside down with the bottom cut off makes a good carburetor funnel for filling the bowl. The pointed little cap on top will go right in the vent tube.
Re: How do you fill fuel bowl on six pack pre-start? [Re: Dave Watt] #719199
06/10/10 11:18 AM
06/10/10 11:18 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
dude that's a good idea.
Re: How do you fill fuel bowl on six pack pre-start? [Re: Dodge Don] #719200
06/10/10 11:37 AM
06/10/10 11:37 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Electric fuel pump works well.
Re: How do you fill fuel bowl on six pack pre-start? [Re: ZIPPY] #719201
06/10/10 11:48 AM
06/10/10 11:48 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
You smart allic...
I just spun my motors over a few times and it started right up when it was new with a mech pump.
