Front wheel wobble after wheelie?? #714988
06/03/10 12:40 PM
06/03/10 12:40 PM
florida
crooksduster Offline OP
florida
I was wondering if anyone could tell me what causes this and what I can do to fix the problem. My front end is stock with 90/10 shocks and is probably pretty warn out. If u pause/play the video, its pretty scary how bad it wobbles in and out..
http://www.youtube.com/watch?v=A_mSJcJBFmQ
Re: Front wheel wobble after wheelie?? [Re: crooksduster] #714989
06/03/10 12:46 PM
06/03/10 12:46 PM
Q
Quicktree Offline
Quicktree  Offline
Q
check for worn front suspension parts. I would replace the shocks if they are old and worn out.
Re: Front wheel wobble after wheelie?? [Re: crooksduster] #714990
06/03/10 12:47 PM
06/03/10 12:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just the standard toe change... do a toe curve to
see what you have.... assuming you have good parts
Re: Front wheel wobble after wheelie?? [Re: Quicktree] #714991
06/03/10 12:50 PM
06/03/10 12:50 PM
Az
Crizila Offline
Crizila  Offline
Az
plus not enough caster.
Fastest 300
Re: Front wheel wobble after wheelie?? [Re: MR_P_BODY] #714992
06/03/10 07:57 PM
06/03/10 07:57 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
check that steering box for excessive play too..what a wobble when it came down...check those tierod ends out as well...
time for a front end rebuild or replacement..
Re: Front wheel wobble after wheelie?? [Re: smokinwoody] #714993
06/04/10 08:48 AM
06/04/10 08:48 AM
Addison,IL
OUTLAWSSAA Online content
OUTLAWSSAA  Online Content
Addison,IL
Whenever I've had that problem,its always been the idler arm bushing.Disconnect the idler arm from the draglink and see if there's any play in the bushing.
Re: Front wheel wobble after wheelie?? [Re: OUTLAWSSAA] #714994
06/04/10 01:04 PM
06/04/10 01:04 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Mine does exactly the same thing, all the front suspension pieces are new..... except the idler arm bushing
Re: Front wheel wobble after wheelie?? [Re: Tig] #714995
06/04/10 02:24 PM
06/04/10 02:24 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thats the first place I would look
Re: Front wheel wobble after wheelie?? [Re: Quicktree] #714996
06/04/10 07:23 PM
06/04/10 07:23 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I always thought it was bump steer. A lot of the SS/AH cars do this. Would a stiffer idler bushing help/eliminate the problem? I need to rebuild the front end on my 1969 Barracuda, so I could make the changes while I have it all apart.
Floyd Lippencott IV
Re: Front wheel wobble after wheelie?? [Re: mr_340] #714997
06/04/10 08:02 PM
06/04/10 08:02 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
same thing here, with all new parts. i have'nt really looked closely to see if i can do this yet, but in my mind i'd like to put the tie rods on the top of the spindle by means of a heim joint on the outers and ream the spindles out to accept a shouldered bolt. that would keep the alignment straighter.
Re: Front wheel wobble after wheelie?? [Re: OUTLAWSSAA] #714998
06/04/10 09:42 PM
06/04/10 09:42 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
Re: Front wheel wobble after wheelie?? [Re: mr_340] #714999
06/05/10 05:23 PM
06/05/10 05:23 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Bingo...bump steer, guys, first all the front end parts must be in tip-top shape, then ya gotta plot the toe changes as the chassis rises and correct it. Time to get out the DC chassis manual; it covers it very well and what to do to correct it.
Re: Front wheel wobble after wheelie?? [Re: Sixpak] #715000
06/05/10 09:57 PM
06/05/10 09:57 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
This is correct, it's a bumpsteer issue. New parts may help, but it won't fix it.
Monte
Re: Front wheel wobble after wheelie?? [Re: Monte_Smith] #715001
06/06/10 01:27 AM
06/06/10 01:27 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Bumpsteer
When you have this the toe is out causing the tires to hit the ground turned out. Then they tug and try to jerk back. The more slack in your steering components and the more it does this.
You can limit travel. This limits some of the characteristics that can't be fixed on a stock front suspension.
