Re: Front wheel wobble after wheelie??
[Re: OUTLAWSSAA]
#714994
06/04/10 01:04 PM
06/04/10 01:04 PM
Posts: 2,923 A shed in England
Tig
A shed in England
Mine does exactly the same thing, all the front suspension pieces are new..... except the idler arm bushing
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#714995
06/04/10 02:24 PM
06/04/10 02:24 PM
Quicktree
thats the first place I would look
[Re: Quicktree]
#714996
06/04/10 07:23 PM
06/04/10 07:23 PM
Posts: 3,504 DFW
mr_340
DFW
I always thought it was bump steer. A lot of the SS/AH cars do this. Would a stiffer idler bushing help/eliminate the problem? I need to rebuild the front end on my 1969 Barracuda, so I could make the changes while I have it all apart.
Floyd Lippencott IV
[Re: OUTLAWSSAA]
#714998
06/04/10 09:42 PM
06/04/10 09:42 PM
Posts: 316 Ohio
Lil Wedge
Ohio
[Re: mr_340]
#714999
06/05/10 05:23 PM
06/05/10 05:23 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
Bingo...bump steer, guys, first all the front end parts must be in tip-top shape, then ya gotta plot the toe changes as the chassis rises and correct it. Time to get out the DC chassis manual; it covers it very well and what to do to correct it.
[Re: Monte_Smith]
#715001
06/06/10 01:27 AM
06/06/10 01:27 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Bumpsteer
When you have this the toe is out causing the tires to hit the ground turned out. Then they tug and try to jerk back. The more slack in your steering components and the more it does this.
You can limit travel. This limits some of the characteristics that can't be fixed on a stock front suspension.
