Energy Suspension A-body master kit #712900
06/01/10 12:47 AM
06/01/10 12:47 AM
Tustin, CA
P
pishta Offline OP
pishta  Offline OP
P
Tustin, CA
Im not a front end expert, but I know what most of these bushings are for. Of course there are no descriptions of what these bushings go to, so: What are the large bushings for that are circled? The lower ones have slots in the ID, the upper ones are larger and are smooth. Most others I labeled. Maybe front leaf bushings?
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: Energy Suspension A-body master kit [Re: pishta] #712901
06/01/10 01:16 AM
06/01/10 01:16 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
They are front leaf eye bushings. There are two different diameters used in A-bodies. So they give you both to cover you. Cool!
My 68 340 original rear spring car had the larger diameter that was the same diameter as my 71 Challenger R/T. I'm guessing the smaller diameter is for the /6 and/or non HD suspension cars.
I bought a kit from Mancini once for my Barracuda that had the small diameter bushings only.
I looks like they are giving you two sets of front leaf spring eye metel sleeves. Are those different ID and/or OD? Are they different width?
OR that is the second set of sleeves shorter sway bar sleeves for those two shorter sway bar end link bolts???
