Page 3 of 3 1 2 3
Re: DYNOJET DYNO RESULTS FROM JAKES! [Re: Labratt] #707875
05/27/10 04:28 AM
05/27/10 04:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Marc,thanks a LOT for posting the link! I've never done it before! Bummer you have to leave town! Raff,I'd love to try out your carb! I would definately need an adapter! What kind of jetting does it currently have? Most likely have to drop a couple #'s! Maybe I should pick it up tomorrow or friday to re-jet,if need be! Not sure about dominator jetting,though! Maybe we can get some suggestions????? Anyone?????
Right now it doesnt have any jets in it... the 8896
came with 88s squared so if you dropped 2 jets in
the 4150 I can set it up with 86s squared and use
that as base line.... give me a call in the morning
but not from 11 to 12:30(therapy).... call about 10
and makbe you can come over about 1:00 .... I'll
have to pull that adapter off my W-5 manifold...
no big deal its all sitting in the shop on the welding
table
Re: DYNOJET DYNO RESULTS FROM JAKES! [Re: MR_P_BODY] #707876
05/27/10 08:37 AM
05/27/10 08:37 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Sounds good! 86 jets might be too much! Right now I've got 82p-81s w/ PV in primary! What do you think??? Also,at 6,000rpm peak power,what should my shift point be? Peak torque was at 5200rpm. Steve(dyno operator)was thinking 7000! I think that's a little on the high side,isn't it? I'll give ya a call in a short while! BTW...pulled a couple of plugs yesterday,NEVER saw them look so GOOD!!! Those A/F sensor's are the "Cat's Ass" for tuning! Even smells better,and that's before adding my bottle of liquid cotton candy!
Re: DYNOJET DYNO RESULTS FROM JAKES! [Re: Labratt] #707877
05/27/10 09:30 AM
05/27/10 09:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Check and see what that carb number is... if the jetting
now is only a couple below the normal that it calls
for I'll leave the 1050 at 86... its all about the
amount of air per carb to what the jet is(basically
a percentage of jet to air)... give me a call now if
you can I have some other questions also
Oh I forgot, you MIGHT not see a number since I cut
the air horn... but check... I want to look up the
base jets
Re: DYNOJET DYNO RESULTS FROM JAKES! [Re: Labratt] #707878
05/27/10 02:04 PM
05/27/10 02:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Randy I pulled the jets again and dropped them to
84 squared so it should be close... maybe a tad fat
but I would prefer to start out fat... its ready for
your pick up.... you will have to look at the front
of the fuel log to see which direction you want the
AN fitting... right now I have as 90* in there
Re: DYNOJET DYNO RESULTS FROM JAKES! [Re: MR_P_BODY] #707879
05/27/10 10:28 PM
05/27/10 10:28 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Mike! Here's a pic of my fuel line to carb set-up. I believe it is 6-AN! I just sent you a PM! Randy
Re: DYNOJET DYNO RESULTS FROM JAKES! [Re: Labratt] #707880
05/27/10 10:56 PM
05/27/10 10:56 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
How did you like the Demon which looks to be an annular booster to the Holley, I assume the holley is downleg booster?
Re: DYNOJET DYNO RESULTS FROM JAKES! [Re: Joshs68] #707881
05/27/10 11:01 PM
05/27/10 11:01 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Josh,I need to sell that Demon to someone who can get it to run leaner at idle! I tried everything,but nothing worked! Too rich! The MD has Annular boosters,but the current Holley has downleg boosters. Take care! RandyB
Re: DYNOJET DYNO RESULTS FROM JAKES! [Re: Hemiroid] #707882
05/27/10 11:34 PM
05/27/10 11:34 PM
Clinton Twp, Michigan
DerickS Offline
DerickS  Offline
Well boys,Lapeer sounds like a VERY GOOD possibility for me and the X on Sunday! What time do the gates open? Raff,too bad your Domi's E-85! I'd be real curious to see how the 440 likes it! BTW...has anyone had a chance to check out my dyno run video on You Tube yet??? It's only about 30 seconds long!
DOH!!
I have to go to Ohio for my nephews graduation!! I'd try to duck out and show up at LaPeer, but the with my wife that would follow wouldn't be pretty. She doesn't ask for much, so I really gotta go . It figures the one time when peeps are going to the track that's 10, that's right 10 blasted miles from my house I have to be out of town . Anyway, best of luck to you guys and have a great time!!
Hey does the wife want her skirt back from you yet??? I hear she's tired of wearing the pants in your house
Re: DYNOJET DYNO RESULTS FROM JAKES! [Re: Labratt] #707883
05/28/10 07:28 AM
05/28/10 07:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I hope there is about 1" or so of play in that line
coming up from the pump otherwise it might be short...
I'll let you play with that to see
Re: DYNOJET DYNO RESULTS FROM JAKES! [Re: DerickS] #707884
05/28/10 09:47 AM
05/28/10 09:47 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
---ZING!---
Rich H.
Esse Quam Videri
Re: DYNOJET DYNO RESULTS FROM JAKES! [Re: ZIPPY] #707885
05/28/10 09:54 AM
05/28/10 09:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
---ZING!---
Zippy... are you ready for Sunday..... Randy just
left my place ... picked up my dom ... going to make
sure it all fits before we hit the track
Re: DYNOJET DYNO RESULTS FROM JAKES! [Re: MR_P_BODY] #707886
05/28/10 11:54 AM
05/28/10 11:54 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I think so Mike.
I'm going to run some fresh gas through it and shake it down on the street Friday/Saturday, if there aren't any issues I'm good to go.
If I get a little extra time I might try to loosen up the front end a little also (shock change and swaybar removal), that never made a difference in the past but maybe it will now....
....but there's no mad dash thrash going on or anything like that.
Re: DYNOJET DYNO RESULTS FROM JAKES! [Re: ZIPPY] #707887
05/28/10 12:18 PM
05/28/10 12:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think so Mike.
... cool.. looks like Doug (doc) will be
coming out also
Re: DYNOJET DYNO RESULTS FROM JAKES! [Re: MR_P_BODY] #707888
05/28/10 02:27 PM
05/28/10 02:27 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The air might be bad, but If nothing else it'll be a good time to test my half baked cooling system.....I've got a '69 Mustang fan shroud cut in half, and alot of other high tech devices to test
Weather is now calling for 88 degrees, and in a couple minutes I'm taking my late lunch hour to go shopping for an
EZ UP
If it's too hot for me I'll just leave a little earlier, I have a potential family gig to go to but can show up in the afternoon for that.
Rich H.
Esse Quam Videri
Re: DYNOJET DYNO RESULTS FROM JAKES! [Re: ZIPPY] #707889
05/28/10 02:39 PM
05/28/10 02:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
EZ UP
Rich check out my post I just posted.... got that
covered plus I have a awning
Re: DYNOJET DYNO RESULTS FROM JAKES! [Re: DerickS] #707890
05/28/10 06:43 PM
05/28/10 06:43 PM
Hemiroid Offline
Hemiroid  Offline
DOH!!
Why I otta.... Go play with your lawn mowers and leave me alone. I hope all of them get flat tires
Re: DYNOJET DYNO RESULTS FROM JAKES! [Re: Hemiroid] #707891
05/28/10 07:27 PM
05/28/10 07:27 PM
DerickS Offline
DerickS  Offline
DOH!!
Get it right! None of them can currently mow grass Hey, how many tires is that????
Page 3 of 3 1 2 3
