Re: DYNOJET DYNO RESULTS FROM JAKES!
[Re: Labratt]
#707875
05/27/10 04:28 AM
05/27/10 04:28 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Marc,thanks a LOT for posting the link! I've never done it before! Bummer you have to leave town! Raff,I'd love to try out your carb! I would definately need an adapter! What kind of jetting does it currently have? Most likely have to drop a couple #'s! Maybe I should pick it up tomorrow or friday to re-jet,if need be! Not sure about dominator jetting,though! Maybe we can get some suggestions????? Anyone?????
Right now it doesnt have any jets in it... the 8896 came with 88s squared so if you dropped 2 jets in the 4150 I can set it up with 86s squared and use that as base line.... give me a call in the morning but not from 11 to 12:30(therapy).... call about 10 and makbe you can come over about 1:00 .... I'll have to pull that adapter off my W-5 manifold... no big deal its all sitting in the shop on the welding table
[Re: Labratt]
#707877
05/27/10 09:30 AM
05/27/10 09:30 AM
MR_P_BODY
Check and see what that carb number is... if the jetting now is only a couple below the normal that it calls for I'll leave the 1050 at 86... its all about the amount of air per carb to what the jet is(basically a percentage of jet to air)... give me a call now if you can I have some other questions also Oh I forgot, you MIGHT not see a number since I cut the air horn... but check... I want to look up the base jets
[Re: Labratt]
#707878
05/27/10 02:04 PM
05/27/10 02:04 PM
MR_P_BODY
Randy I pulled the jets again and dropped them to 84 squared so it should be close... maybe a tad fat but I would prefer to start out fat... its ready for your pick up.... you will have to look at the front of the fuel log to see which direction you want the AN fitting... right now I have as 90* in there
[Re: Hemiroid]
#707882
05/27/10 11:34 PM
05/27/10 11:34 PM
Posts: 1,562 Clinton Twp, Michigan
DerickS
Well boys,Lapeer sounds like a VERY GOOD possibility for me and the X on Sunday! What time do the gates open? Raff,too bad your Domi's E-85! I'd be real curious to see how the 440 likes it! BTW...has anyone had a chance to check out my dyno run video on You Tube yet??? It's only about 30 seconds long!
DOH!!
I have to go to Ohio for my nephews graduation!! I'd try to duck out and show up at LaPeer, but the with my wife that would follow wouldn't be pretty. She doesn't ask for much, so I really gotta go . It figures the one time when peeps are going to the track that's 10, that's right 10 blasted miles from my house I have to be out of town . Anyway, best of luck to you guys and have a great time!!
Hey does the wife want her skirt back from you yet??? I hear she's tired of wearing the pants in your house
[Re: Labratt]
#707883
05/28/10 07:28 AM
05/28/10 07:28 AM
MR_P_BODY
Thanks,Mike! Here's a pic of my fuel line to carb set-up. I believe it is 6-AN! I just sent you a PM! Randy
I hope there is about 1" or so of play in that line coming up from the pump otherwise it might be short... I'll let you play with that to see
[Re: ZIPPY]
#707885
05/28/10 09:54 AM
05/28/10 09:54 AM
MR_P_BODY
---ZING!---
Zippy... are you ready for Sunday..... Randy just left my place ... picked up my dom ... going to make sure it all fits before we hit the track
[Re: ZIPPY]
#707887
05/28/10 12:18 PM
05/28/10 12:18 PM
MR_P_BODY
I think so Mike.
I'm going to run some fresh gas through it and shake it down on the street Friday/Saturday, if there aren't any issues I'm good to go.
If I get a little extra time I might try to loosen up the front end a little also (shock change and swaybar removal), that never made a difference in the past but maybe it will now....
....but there's no mad dash thrash going on or anything like that.
... cool.. looks like Doug (doc) will be coming out also
[Re: MR_P_BODY]
#707888
05/28/10 02:27 PM
05/28/10 02:27 PM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
The air might be bad, but If nothing else it'll be a good time to test my half baked cooling system.....I've got a '69 Mustang fan shroud cut in half, and alot of other high tech devices to test Weather is now calling for 88 degrees, and in a couple minutes I'm taking my late lunch hour to go shopping for an EZ UP If it's too hot for me I'll just leave a little earlier, I have a potential family gig to go to but can show up in the afternoon for that.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#707889
05/28/10 02:39 PM
05/28/10 02:39 PM
MR_P_BODY
Rich check out my post I just posted.... got that covered plus I have a awning
[Re: DerickS]
#707890
05/28/10 06:43 PM
05/28/10 06:43 PM
Posts: 705 Michigan
Hemiroid
DOH!!
Why I otta.... Go play with your lawn mowers and leave me alone. I hope all of them get flat tires
[Re: Hemiroid]
#707891
05/28/10 07:27 PM
05/28/10 07:27 PM
DerickS
DOH!!
Get it right! None of them can currently mow grass Hey, how many tires is that????
