Pitman seal kit Question #706559
05/24/10 01:50 PM
05/24/10 01:50 PM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
Is there someone who know where I can buy a Pitman seal kit to my AAR cuda power steering?
Re: Pitman seal kit Question [Re: AAR70] #706560
05/24/10 02:53 PM
05/24/10 02:53 PM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
any good parts person from a real parts store should be able to help with that. these are edelman numbers. lower seal kit is #8517. complete pitman kit is number #8759. hope this helps.
71 scamp big block with 915 heads 727 trans
Re: Pitman seal kit Question [Re: 71scamp440] #706561
05/24/10 02:55 PM
05/24/10 02:55 PM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
i just noticed that your in denmark. if you cant find one let me know and i could order one and ship it over the pond.
Re: Pitman seal kit Question [Re: 71scamp440] #706562
05/24/10 03:12 PM
05/24/10 03:12 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
are you looking for the boot or the seal that goes in the power steering? i couldnt find the boot
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Pitman seal kit Question [Re: aarcuda] #706563
05/24/10 03:51 PM
05/24/10 03:51 PM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
I am looking for steering gear pitman shaft seal.I have here in denmark a Edelman kit with part # 8517 but the seals are to small.The part #8517 kit is for 1 1/8 inch shaft diameter but the correkt AAR size is 1 1/4 inch diameter.I think edelman part # 8516 is the right part #.
http://www.rockauto.com/catalog/x,carcode,1435881,parttype,7344,a,www.google.dk%2BSearch%2Bfor%2BSteering%2BSteering%2BGear%2BPitman%2BShaft%2BSeal%2BEDELMANN
http://www.rockauto.com/catalog/x,carcode,1231726,parttype,7344,a,www.google.dk%2BSearch%2Bfor%2BSteering%2BSteering%2BGear%2BPitman%2BShaft%2BSeal%2BEDELMANN
Re: Pitman seal kit Question [Re: AAR70] #706564
05/24/10 04:43 PM
05/24/10 04:43 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Does your car have an original AAR/TA fast ratio box? It will have a T/A casted into the side of it.
I'm not certain if those have the larger 1.22 output shaft dia. I didn't think so, but I am not 100% sure
The 1973 and up A/B/E bodies with power steering all had 1.22 output shaft. And WITH the right pitman arm you can put those in most earlier A/B/E bodies. Many times those get swapped in earier cars.
Re: Pitman seal kit Question [Re: autoxcuda] #706565
05/24/10 04:59 PM
05/24/10 04:59 PM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
yes, the steering housing have T/A casted in the side of it ,and the shaft is 1,22 inch
Re: Pitman seal kit Question [Re: AAR70] #706566
05/24/10 05:32 PM
05/24/10 05:32 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Get the seal for a 73 and up B/E/A body that has the large output shaft. Search for a car like a 1974 Dodge Challenger 360 (5.9L)
I believe a 71 C-body will also have that 1.22 output shaft. I bet the seal for a 71 Chrysler Newport 383 is the same for 74 Challenger 360. Not 100% sure, I haven't looked it up on Rock Auto.
Alaskan T/A posted a factory TSB bulletin a month or so back that described some of the repair/service stuff for the Quick Ration power steering systems. I think it might have addressed the output seal in there. Can't remember.
Re: Pitman seal kit Question [Re: autoxcuda] #706567
05/25/10 04:25 PM
05/25/10 04:25 PM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
Hey,thank you for help,
I have 8516 on order today.
Lau
