Re: Pitman seal kit Question
[Re: AAR70]
#706560
05/24/10 02:53 PM
05/24/10 02:53 PM
Posts: 417 jamestown, ny
71scamp440
Hinged
Hinged
jamestown, ny
any good parts person from a real parts store should be able to help with that. these are edelman numbers. lower seal kit is #8517. complete pitman kit is number #8759. hope this helps.
71 scamp
big block with 915 heads
727 trans
[Re: 71scamp440]
#706561
05/24/10 02:55 PM
05/24/10 02:55 PM
71scamp440
Hinged
Hinged
jamestown, ny
i just noticed that your in denmark. if you cant find one let me know and i could order one and ship it over the pond.
71 scamp
727 trans
[Re: 71scamp440]
#706562
05/24/10 03:12 PM
05/24/10 03:12 PM
Posts: 15,491 the boonies
aarcuda
the boonies
are you looking for the boot or the seal that goes in the power steering? i couldnt find the boot
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
[Re: aarcuda]
#706563
05/24/10 03:51 PM
05/24/10 03:51 PM
Posts: 210 Denmark, Helsingor
AAR70
Denmark, Helsingor
I am looking for steering gear pitman shaft seal.I have here in denmark a Edelman kit with part # 8517 but the seals are to small.The part #8517 kit is for 1 1/8 inch shaft diameter but the correkt AAR size is 1 1/4 inch diameter.I think edelman part # 8516 is the right part #. http://www.rockauto.com/catalog/x,carcode,1435881,parttype,7344,a,www.google.dk%2BSearch%2Bfor%2BSteering%2BSteering%2BGear%2BPitman%2BShaft%2BSeal%2BEDELMANN http://www.rockauto.com/catalog/x,carcode,1231726,parttype,7344,a,www.google.dk%2BSearch%2Bfor%2BSteering%2BSteering%2BGear%2BPitman%2BShaft%2BSeal%2BEDELMANN
[Re: AAR70]
#706564
05/24/10 04:43 PM
05/24/10 04:43 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
Does your car have an original AAR/TA fast ratio box? It will have a T/A casted into the side of it. I'm not certain if those have the larger 1.22 output shaft dia. I didn't think so, but I am not 100% sure The 1973 and up A/B/E bodies with power steering all had 1.22 output shaft. And WITH the right pitman arm you can put those in most earlier A/B/E bodies. Many times those get swapped in earier cars. Quote:
[Re: autoxcuda]
#706565
05/24/10 04:59 PM
05/24/10 04:59 PM
AAR70
Denmark, Helsingor
yes, the steering housing have T/A casted in the side of it ,and the shaft is 1,22 inch
[Re: autoxcuda]
#706567
05/25/10 04:25 PM
05/25/10 04:25 PM
AAR70
Denmark, Helsingor
Get the seal for a 73 and up B/E/A body that has the large output shaft. Search for a car like a 1974 Dodge Challenger 360 (5.9L)
I believe a 71 C-body will also have that 1.22 output shaft. I bet the seal for a 71 Chrysler Newport 383 is the same for 74 Challenger 360. Not 100% sure, I haven't looked it up on Rock Auto.
Alaskan T/A posted a factory TSB bulletin a month or so back that described some of the repair/service stuff for the Quick Ration power steering systems. I think it might have addressed the output seal in there. Can't remember.
Hey,thank you for help,
I have 8516 on order today.
Lau
