using a used torque converter?? #706439
05/24/10 11:29 AM
05/24/10 11:29 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
need a hi stall for my 69 fury [engine has a hot cam of unknows spec] i have an orig 340 hi stall with over 100k miles but trans fluid looked good and i drove car so i know it worked.. what wears out in them? is there a way to ck it out of the car? trans in fury looks to have been rebuilt recently also lmk trans guys dan
Re: using a used torque converter?? [Re: ph23vo] #706440
05/24/10 11:54 AM
05/24/10 11:54 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
If it's factory it should have a drain. Drain the old fluid out of it thru a paint strainer. If it's clean and red, and there's no metal in the strainer after, just pre-fill it with a quart of fresh stuff and use it. Be aware the stall will not be what it was with the 340 tho.
Re: using a used torque converter?? [Re: moper] #706441
05/24/10 12:19 PM
05/24/10 12:19 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
yes i know thanks for the advice dan
Re: using a used torque converter?? [Re: ph23vo] #706442
05/24/10 12:33 PM
05/24/10 12:33 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Not all OEM TC's had drain-plugs .. most did though. Buying and then using a used converter is TAKING-A-CHANCE. Just like a used cam(a topic I started a bit ago). Draining the ATF and checking-that is a good start but not a guarantee. ALSO ... if the converter is junk .. it could hurt the trans itself.
Bottom line ... it is a gamble.
Re: using a used torque converter?? [Re: dOc !] #706443
05/24/10 12:52 PM
05/24/10 12:52 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
this is a converter i had in my 70 challenger i drove it about 6 months worked great has sat in garage since late 80,s sealed up so at least i know it did work! dan
Re: using a used torque converter?? [Re: ph23vo] #706444
05/24/10 02:07 PM
05/24/10 02:07 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
SHOULD BE good-to go !
You should have had one of my full-coverage hub covers to protect the hub and keep all the dust and dirt out.
Re: using a used torque converter?? [Re: dOc !] #706445
05/24/10 03:23 PM
05/24/10 03:23 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
i do have one but it isnt one of yours doc dan
Re: using a used torque converter?? [Re: moper] #706446
05/24/10 04:39 PM
05/24/10 04:39 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Why's that?
Re: using a used torque converter?? [Re: Commando1] #706447
05/24/10 04:57 PM
05/24/10 04:57 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
383 has more torque.. just pulled it out of storage fluid is bright red so i,m good to go! dan
