Re: using a used torque converter??
[Re: ph23vo]
#706440
05/24/10 11:54 AM
05/24/10 11:54 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
If it's factory it should have a drain. Drain the old fluid out of it thru a paint strainer. If it's clean and red, and there's no metal in the strainer after, just pre-fill it with a quart of fresh stuff and use it. Be aware the stall will not be what it was with the 340 tho.
