Re: Mini tubs, E body
[Re: desomod]
#704437
05/22/10 10:37 AM
05/22/10 10:37 AM
Posts: 1,572 Jacksonville Florida
elitecustombody
Buy a new set of AMD inner wheelhoses ,cut the old ones out leaving 3 inch wide strip ,weld new ones in ,alot less work and job is so much cleaner, I just finished mini-tubbing 69 Dart,it was a piece of cake, as mentioned above, trunk hinge bracket is a two piece,you'll have to eliminate the lower section ,on A-body I didn't even have to reshape it,it butted up nicely against the inner wheelhouse and looks factory
[Re: elitecustombody]
#704438
05/22/10 10:40 AM
05/22/10 10:40 AM
Posts: 6,295 U.S.
moparniac
U.S.
you can get a 315/60/15 in there with stock wheeltubs....
Mopar Performance
[Re: desomod]
#704440
05/22/10 06:20 PM
05/22/10 06:20 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
How much do you actually gain on an e-body with the rails being so close to the wheelhouse in back? I thought you had to notch the rail also.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
