Mini tubs, E body #704434
05/21/10 04:51 PM
05/21/10 04:51 PM
desomod Offline OP
desomod  Offline OP
Is there a post here on constructing mini tubs for the E-body? I remember an article in one of the magazines where they installed a 2-3" expansion by cutting and moving the inner wheel well inboard and filling the space with a strip of metal. The car is a 4-link so there is plenty of room without the leaf springs. My question is with the trunklid supports that are formed and tacked to the inner fenders and how to best modify/move them. Any tips here?
Re: Mini tubs, E body [Re: desomod] #704435
05/21/10 07:17 PM
05/21/10 07:17 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
You do not have to move the deck-lid spring bracket when you mini tub. All you have to do is shorten it up because after you tub it, the bracket will now end up on top of the wheel-well instead of on the side of the wheel-well. I am not familiar with the e body bracket but many are two piece, this allows you to drill out the spot wells on the spring bracket and allows you to reshape it to fit back in after you mini-tub the wheel-well. I have done many mini tubs and you cannot tell it has been done when I finish except for the fact it looks wider inside the trunk. If you need more info on mini-tubs PM me. Hope this helps.
Re: Mini tubs, E body [Re: desomod] #704436
05/21/10 07:31 PM
05/21/10 07:31 PM
United States
V
v269 Offline
v269  Offline
V
United States
Re: Mini tubs, E body [Re: desomod] #704437
05/22/10 10:37 AM
05/22/10 10:37 AM
Jacksonville Florida
elitecustombody Offline
Buy a new set of AMD inner wheelhoses ,cut the old ones out leaving 3 inch wide strip ,weld new ones in ,alot less work and job is so much cleaner, I just finished mini-tubbing 69 Dart,it was a piece of cake, as mentioned above, trunk hinge bracket is a two piece,you'll have to eliminate the lower section ,on A-body I didn't even have to reshape it,it butted up nicely against the inner wheelhouse and looks factory
Re: Mini tubs, E body [Re: elitecustombody] #704438
05/22/10 10:40 AM
05/22/10 10:40 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
you can get a 315/60/15 in there with stock wheeltubs....
Mopar Performance
Re: Mini tubs, E body [Re: elitecustombody] #704439
05/22/10 04:37 PM
05/22/10 04:37 PM
United States
V
v269 Offline
v269  Offline
V
United States
thats a great idea, wish i had thought of that
Re: Mini tubs, E body [Re: desomod] #704440
05/22/10 06:20 PM
05/22/10 06:20 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
How much do you actually gain on an e-body with the rails being so close to the wheelhouse in back? I thought you had to notch the rail also.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Mini tubs, E body [Re: Silver70] #704441
05/22/10 09:09 PM
05/22/10 09:09 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Yep, you don't gain much without notching the framerail.
Re: Mini tubs, E body [Re: GomangoCuda] #704442
05/23/10 10:15 AM
05/23/10 10:15 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Moving the springs inboard will net you some tire http://www.moparts.org/Tech/Archive/rearsusp/12.html
