Re: difference between B and E 4spds
[Re: DaytonaTurbo]
#70171
06/09/08 01:18 AM
06/09/08 01:18 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
Everything's different enough to not work. The E body stuff interchanges with the 71+ b bodies, but not the older ones.
Depending on what tyou are TRYING to do, determines whether or not what you have will work. The later (1970 and on) B/E body tailhousing can be put on the earlier trans. There are 4.80" bearing retainers made in both available bolt circles, so it really does come down to what you need/want to do and what you have onhand already.
2 Demons...no, not my kids!
[Re: cool_cuda]
#70176
06/09/08 10:21 PM
06/09/08 10:21 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
mainly the petals and the tranny with out changing tail stocks or if anyone know who sells repo petal assemblys?
what year trans into what year car ?
peDals you needd the correct stuff for the body you have , they aren't interchangable between the 2 different platforms you are asking about ...
and no repops other than maybe kiesler ???
