difference between B and E 4spds #70168
06/08/08 10:22 PM
06/08/08 10:22 PM
ontario, canada
cool_cuda Offline OP
ontario, canada
okay guys i need your help are 66-68 B-body 4spds the same as B and E 71's?
will the clutch petals line up?
thanks
Re: difference between B and E 4spds [Re: cool_cuda] #70169
06/08/08 11:28 PM
06/08/08 11:28 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
70 and up b and e have a different tail housing, There are different front collar sizes for small and big block but the pedals would line up as you ask. Not sure what you mean there, but the trans it self is the same length in b and e back to around 66 and up to 74.
Re: difference between B and E 4spds [Re: cool_cuda] #70170
06/09/08 01:14 AM
06/09/08 01:14 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Everything's different enough to not work. The E body stuff interchanges with the 71+ b bodies, but not the older ones.
Re: difference between B and E 4spds [Re: DaytonaTurbo] #70171
06/09/08 01:18 AM
06/09/08 01:18 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Depending on what tyou are TRYING to do, determines whether or not what you have will work. The later (1970 and on) B/E body tailhousing can be put on the earlier trans. There are 4.80" bearing retainers made in both available bolt circles, so it really does come down to what you need/want to do and what you have onhand already.
2 Demons...no, not my kids!
Re: difference between B and E 4spds [Re: 4speeds4me] #70172
06/09/08 07:45 AM
06/09/08 07:45 AM
ontario, canada
ontario, canada
okay thanks guys for all the help i didnt think it would work
Re: difference between B and E 4spds [Re: cool_cuda] #70173
06/09/08 12:53 PM
06/09/08 12:53 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
what parts EXACTLY are you asking about ?
Re: difference between B and E 4spds [Re: JohnRR] #70174
06/09/08 06:25 PM
06/09/08 06:25 PM
ontario, canada
ontario, canada
mainly the tranny and petal's
Re: difference between B and E 4spds [Re: JohnRR] #70175
06/09/08 06:26 PM
06/09/08 06:26 PM
ontario, canada
ontario, canada
mainly the petals and the tranny with out changing tail stocks or if anyone know who sells repo petal assemblys?
Re: difference between B and E 4spds [Re: cool_cuda] #70176
06/09/08 10:21 PM
06/09/08 10:21 PM
JohnRR Offline
JohnRR  Offline
what year trans into what year car ?
peDals you needd the correct stuff for the body you have , they aren't interchangable between the 2 different platforms you are asking about ...
and no repops other than maybe kiesler ???
