Street roller cams
#696732
05/12/10 10:19 PM
05/12/10 10:19 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Just curious if any of the people who run rollers in street cars use the street roller cams that use less spring pressure then race rollers ?? Thinking about using a roller in my next eng for my 63 but I do drive it alot on the street. Ron
Re: Street roller cams
[Re: 383man]
#696733
05/12/10 10:26 PM
05/12/10 10:26 PM
Triple Threat
Renton Washington
Run a Hydraulic roller grind, but use solid roller lifters. Or there are various street grinds as well, depending on how wild you're looking to go.
[Re: 383man]
#696735
05/12/10 11:17 PM
05/12/10 11:17 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
Hi Ron i have a used comp solid street roller i would sell cheep. please pm me if you are interested.OK back to your question. This will be my first time using a solid roller cam my self. so i don't have much info to give you. but i will be trying a comp solid roller in my 73 440 dart soon. I plan on driving it on the street once in a while and my cam is 264 @ 0.50 and 634 lift with my 1.6 roller rockers. every body i talk to says i will love the roller so we will see.mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: MIKES_DUSTER]
#696738
05/13/10 12:30 AM
05/13/10 12:30 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Ron, Ive talked to Dwayne at length about this on a couple occasions. He says the -5 Comp lobes are very very reliable in a real street driven application.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Thumperdart]
#696743
05/13/10 03:16 PM
05/13/10 03:16 PM
Posts: 9,146 Now - Port Orange,Fla. Former...
MIKES_DUSTER
My cam is about as big as Isky generally uses in a daily driver situation and has served me well for over five years. After my 9-sec pass, I decided to change out the springs and the old ones were somewhere around 220-230 on the seat and 480 open and I drive it a lot and had several passes at that time. I swapped to a stouter spring and it`s still goin strong w/240-250 seat and 540+ open. I`m not the consertavite type and am of the "bigger is better" theory and so far have proven it can work well.
Just curious what the specs of your cam is??
383man
[Re: ZIPPY]
#696748
05/13/10 08:49 PM
05/13/10 08:49 PM
383man
Balt. Md
Ron,
And Dwayne is right. I got my -5 grind from PRH and it has been very good.
The first design street rollers are nice grinds too, though, and worth checking out if a guy wants to buy a shelf grind.
I was going to go with the older 308 street roller until Dwayne picked out a -5 for me instead. At the time our feeling was the -5 would pick up some power without hurting reliability/longevity enough to notice.
Zippy can I ask you the cam specs on that cam and the spring pressure you run with it ??? Thanks , Ron
Re: 383man
[Re: roadrunnerreds]
#696751
05/14/10 12:46 AM
05/14/10 12:46 AM
Posts: 795 Glendale Az
Darryls-Demon
Glendale Az
darryls-demon your challenger reminds me of a car my aunt had when i was about 8 years old. do you have to bush the lifter bores. Bradley
Bradley, the lifter bores do not need to be bushed. Did your aunt live in Gilbert Az in 1970? I would like to talk to the person who bought the car new.
