Street roller cams #696732
05/12/10 10:19 PM
05/12/10 10:19 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Just curious if any of the people who run rollers in street cars use the street roller cams that use less spring pressure then race rollers ?? Thinking about using a roller in my next eng for my 63 but I do drive it alot on the street. Ron
Re: Street roller cams [Re: 383man] #696733
05/12/10 10:26 PM
05/12/10 10:26 PM
Renton Washington
Triple Threat Offline
Renton Washington
Run a Hydraulic roller grind, but use solid roller lifters. Or there are various street grinds as well, depending on how wild you're looking to go.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Street roller cams [Re: 383man] #696734
05/12/10 11:04 PM
05/12/10 11:04 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
200#/500# is not uncommon on street designed solid rollers.
Re: Street roller cams [Re: 383man] #696735
05/12/10 11:17 PM
05/12/10 11:17 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Hi Ron i have a used comp solid street roller i would sell cheep. please pm me if you are interested.OK back to your question. This will be my first time using a solid roller cam my self. so i don't have much info to give you. but i will be trying a comp solid roller in my 73 440 dart soon. I plan on driving it on the street once in a while and my cam is 264 @ 0.50 and 634 lift with my 1.6 roller rockers. every body i talk to says i will love the roller so we will see.mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Street roller cams [Re: 383man] #696736
05/12/10 11:27 PM
05/12/10 11:27 PM
AndyF Offline
AndyF  Offline
I would use a street roller for a street car. Just seems like a good idea to me.
Re: Street roller cams [Re: Triple Threat] #696737
05/12/10 11:32 PM
05/12/10 11:32 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
WHY?????
Re: Street roller cams [Re: MIKES_DUSTER] #696738
05/13/10 12:30 AM
05/13/10 12:30 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Ron,
Ive talked to Dwayne at length about this on a couple occasions.
He says the -5 Comp lobes are very very reliable in a real street driven application.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Street roller cams [Re: MIKES_DUSTER] #696739
05/13/10 04:16 AM
05/13/10 04:16 AM
Alberta, Can
JUST_N_TIME Offline
JUST_N_TIME  Offline
Alberta, Can
requires less spring pressures than a solid grind to achieve chances of float and lash is in the ±.006 range - less noise.
Re: Street roller cams [Re: JUST_N_TIME] #696740
05/13/10 05:17 AM
05/13/10 05:17 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
i have been running a smallblock with a comp XE solid roller for a few years on the street and no problems at all, and before that i had a diferent solid roller but much wilder that worked for a few years of summer daily driving including some pretty long drives and alot of 7500+rpm shifts and that one lost alitle spring preasure during the last summer, but none of them realy gave me any trouble being driven on the street for alot of time and both those rollercams have been at cruisenights basicly being at idle for about 8 hours at 8-900rpms with no bad effects that i have noticed
and i dont think a modern solid roller with .016-.018 lash makes enough noice from the lash to realy be anoying to anyone
Re: Street roller cams [Re: 383man] #696741
05/13/10 08:02 AM
05/13/10 08:02 AM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
I run a roller on the street but I don't drive my car much. The thing you want to avoid is a lot of idling. I like the perfomrance of the roller cam. I am running .700 lift and if I remember correctly 240# of seat pressure. What I don't like about the cam is the bronze from the distributor gear in the oil and additional mantenance.
Re: Street roller cams [Re: 383man] #696742
05/13/10 01:52 PM
05/13/10 01:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My cam is about as big as Isky generally uses in a daily driver situation and has served me well for over five years. After my 9-sec pass, I decided to change out the springs and the old ones were somewhere around 220-230 on the seat and 480 open and I drive it a lot and had several passes at that time. I swapped to a stouter spring and it`s still goin strong w/240-250 seat and 540+ open. I`m not the consertavite type and am of the "bigger is better" theory and so far have proven it can work well.
Re: Street roller cams [Re: Thumperdart] #696743
05/13/10 03:16 PM
05/13/10 03:16 PM
Just curious what the specs of your cam is??
Re: Street roller cams [Re: MIKES_DUSTER] #696744
05/13/10 03:26 PM
05/13/10 03:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It`s a custom grind I came up with and it`s .680-.660 lift w/275-280 dur @.050 ground on a 108 lobe center. I don`t have the cam card handy to fully detail it but it`s just a bit different than their shelf grinds and VERY streetable.
Re: Street roller cams [Re: Thumperdart] #696745
05/13/10 03:42 PM
05/13/10 03:42 PM
NICE!!!!!!!
Re: Street roller cams [Re: Von] #696746
05/13/10 04:03 PM
05/13/10 04:03 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Ron,
And Dwayne is right.
I got my -5 grind from PRH and it has been very good.
The first design street rollers are nice grinds too, though, and worth checking out if a guy wants to buy a shelf grind.
I was going to go with the older 308 street roller until Dwayne picked out a -5 for me instead. At the time our feeling was the -5 would pick up some power without hurting reliability/longevity enough to notice.
Rich H.
Esse Quam Videri
383man [Re: ZIPPY] #696747
05/13/10 08:47 PM
05/13/10 08:47 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Thanks for the replies. I know I will need a good strong valvetrain if I use the race roller with the spring pressure they run. Course I want a strong valvetrain no matter what cam I use. Ron
383man [Re: ZIPPY] #696748
05/13/10 08:49 PM
05/13/10 08:49 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Ron,
Zippy can I ask you the cam specs on that cam and the spring pressure you run with it ??? Thanks , Ron
Re: 383man [Re: 383man] #696749
05/13/10 11:18 PM
05/13/10 11:18 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I have a Comp Cams solid street roller in my Challenger. There is about 1500 miles on the motor and so far all is good. The lifter bores have been bushed, I do not know if that helps.
The Cam is small- 248-254@ .050 and .622-.612 lift with 1.6 Rockers. Seat pressure is somthing like 200 on the seat 470 open.
Re: 383man [Re: Darryls-Demon] #696750
05/13/10 11:26 PM
05/13/10 11:26 PM
Gettysburg Pa
roadrunnerreds Offline
Gettysburg Pa
darryls-demon your challenger reminds me of a car my aunt had when i was about 8 years old. do you have to bush the lifter bores. Bradley
Re: 383man [Re: roadrunnerreds] #696751
05/14/10 12:46 AM
05/14/10 12:46 AM
Glendale Az
Glendale Az
Bradley, the lifter bores do not need to be bushed.
Did your aunt live in Gilbert Az in 1970?
I would like to talk to the person who bought the car new.
