Carburetor alternatives, which one? #695309
05/11/10 08:18 PM
05/11/10 08:18 PM
North Central Florida
E
eightlitermopar Offline OP
E
1969 Dodge Coronet
440 based on the car craft build from years ago
with one exception. An alternate to the carburetor.
This car will occasionally see the track, but primarily will be used for cruising and spirited street driving.
I have looked into several options available, and have narrowed it down .
The first option would be a throttle body system from
FAST fuelairspark.com part # 30227-KIT
or
the Edelbrock proflo 2 system
Edelbrock.com # 35090
I am looking for a bolt on and little hassle system, so what are your thoughts?
Pros vs cons etc.
What do you think?
thanks eight
Mopar or no car
Re: Carburetor alternatives, which one? [Re: eightlitermopar] #695310
05/11/10 09:35 PM
05/11/10 09:35 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Look at the Fastman EFI web site. I believe he has a throttle body set-up that he says is self-tuning.
Master, again and still
Re: Carburetor alternatives, which one? [Re: eightlitermopar] #695311
05/11/10 10:15 PM
05/11/10 10:15 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Re: Carburetor alternatives, which one? [Re: Ply72rr] #695312
05/11/10 10:55 PM
05/11/10 10:55 PM
E
E
Thanks for the heads up!
Does anyone on the board here run one of these systems?
Is there a pro con between throttle body and EFI?
Or is it just preference?
Mopar or no car
Re: Carburetor alternatives, which one? [Re: eightlitermopar] #695313
05/11/10 11:18 PM
05/11/10 11:18 PM
IN
ahy Offline
ahy  Offline
IN
I'm running the FAST XFI on a 496 B engine. In general, EFI gives better fuel distribution compared to a carb or throttle body injection.
Either port or throttle injection can provide drivability benefits. They will self adjust for altitude, temperature and variations in fuel energy (eg gasahol vs straight gas). Also, since you will have pressurized fuel going into the engine compartment vapor lock should not be an issue. The fuel injection setups, especially the XFI type, allow you to run plenty of advance and lean mixtures for efficient cruising and quickly richen things up and pull back the timing when you step on it. Its like having a race carb and economy carb in one package whith plenty of vacuum advance only when you want it.
The XFI setup does require considerable tuning and mapping compared to the self learning types. If you enjoy it that's great or get hooked up with somebody to do it for you. The self learning type is a lot easier.
Another consideration is fuel supply. The fuel injection setups require pressurized fuel from an electric pump. A frame rail mounted pump will work but in tank is better. In tank is quieter, longer lasting and allows you to run the tank lower without wory about cavitation or starving the pump.
I love my XFI setup and have enjoyed tuning it.
Re: Carburetor alternatives, which one? [Re: eightlitermopar] #695314
05/12/10 07:15 AM
05/12/10 07:15 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
a bolt on with little hassle is what your asking for - then the EZ efi system sounds right for you - the eddy setup requires a laptop during inital fireup, and I dont know to what extent you need to get into the program, but the FAST Ez efi system is pretty much plug and play - thats a god fit for you it seems.
I'll let you know in a few weeks as I am in the process of the EZ efi kit right now.
I researched and got a fuel pump in the tank from rock valley - they convert a stamped steel tank to an efi, in tank setup.
Re: Carburetor alternatives, which one? [Re: ahy] #695315
05/12/10 10:55 AM
05/12/10 10:55 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
with ahy for the most part. For the fuel pump thing, for mine I've got a sump I'm welding on the bottom of my gas tank, then running an external in-line fuel pump. Pump is a walbro gsl-392. Not my first time using one of these pumps either. They run quiet and have not let me down yet though I don't have many years of use on one yet.
Re: Carburetor alternatives, which one? [Re: DaytonaTurbo] #695316
05/12/10 12:06 PM
05/12/10 12:06 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
There is also the Professional Products PowerJection III setup to consider. I believe the retrotek link above makes it for them or with them or some such scenario, for a bolt on top of carb manifold, self learning system, TBI.
http://www.professional-products.com/EFI_3.php
Good luck!
Re: Carburetor alternatives, which one? [Re: Alikazam] #695317
05/13/10 05:48 AM
05/13/10 05:48 AM
E
E
This is awesome, learning a lot here.
What about Edelbrocks pro flo system? Has anyone run this? I have heard some people don't like these systems. Aren't they a plug and play also once they are dialed in?
thanks again! Lots of resources to consider here!
Mopar or no car
Re: Carburetor alternatives, which one? [Re: eightlitermopar] #695318
05/13/10 07:56 AM
05/13/10 07:56 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
no but my initial research revealed you needed a laptop to get it running, if you make a significant change i dont know if that requires a date with the laptop every time or not.
I do know the ez efi system is all contained, and no laptop needed, whatever changes you make you never need the laptop for a tune.
besides, they are the only ones that will fit on my tunnel ram!
Re: Carburetor alternatives, which one? [Re: DJVCuda] #695319
05/13/10 08:04 AM
05/13/10 08:04 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
850 DEMON. A little rough on warm up. No choke. It's called character. Where is your spirit of adventure. Nostalgia.
Then there is the whaaaaaa. A sound that has no match.
Re: Carburetor alternatives, which one? [Re: DennisH ] #695320
05/13/10 08:14 AM
05/13/10 08:14 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
i've been a carb guy all my life.
having said that is that not " spirit of adventure" to try a modern fuel injection setup?
Re: Carburetor alternatives, which one? [Re: DJVCuda] #695321
05/13/10 10:35 AM
05/13/10 10:35 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I have the pros and cons of TB injection vs port injection on my web site. On the technical download page I also have a few articles that I wrote for a local Mopar club. The articles are start with, "All you wanted to know about EFI but ..."
