Carburetor alternatives, which one?
#695309
05/11/10 08:18 PM
05/11/10 08:18 PM
Posts: 1,630 North Central Florida
eightlitermopar
1969 Dodge Coronet 440 based on the car craft build from years ago with one exception. An alternate to the carburetor. This car will occasionally see the track, but primarily will be used for cruising and spirited street driving. I have looked into several options available, and have narrowed it down . The first option would be a throttle body system from FAST fuelairspark.com part # 30227-KIT or the Edelbrock proflo 2 system Edelbrock.com # 35090 I am looking for a bolt on and little hassle system, so what are your thoughts? Pros vs cons etc. What do you think? thanks eight
Mopar or no car
Re: Carburetor alternatives, which one?
[Re: eightlitermopar]
#695310
05/11/10 09:35 PM
05/11/10 09:35 PM
Posts: 12,162 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Look at the Fastman EFI web site. I believe he has a throttle body set-up that he says is self-tuning.
Master, again and still
#695311
05/11/10 10:15 PM
05/11/10 10:15 PM
Posts: 553 DE
Ply72rr
DE
[Re: Ply72rr]
#695312
05/11/10 10:55 PM
05/11/10 10:55 PM
eightlitermopar
Thanks for the heads up! Does anyone on the board here run one of these systems? Is there a pro con between throttle body and EFI? Or is it just preference?
Mopar or no car
[Re: Alikazam]
#695317
05/13/10 05:48 AM
05/13/10 05:48 AM
eightlitermopar
This is awesome, learning a lot here. What about Edelbrocks pro flo system? Has anyone run this? I have heard some people don't like these systems. Aren't they a plug and play also once they are dialed in? thanks again! Lots of resources to consider here!
Mopar or no car
