no but my initial research revealed you needed a laptop to get it running, if you make a significant change i dont know if that requires a date with the laptop every time or not.
I do know the ez efi system is all contained, and no laptop needed, whatever changes you make you never need the laptop for a tune.
besides, they are the only ones that will fit on my tunnel ram!
