Wilwood brake interferance with Magnum500 wheels #695240
05/11/10 07:24 PM
05/11/10 07:24 PM
Bethlehem Pa.
tinman68 Offline OP
tinman68  Offline OP
Bethlehem Pa.
I am in the process of changing wheels to Magnun500 for a more stock look from aluminum wheels.
the only interferance problem is the screw on WILLWOOD grease cap must be removed in order to install the wheel center caps. any suggestions.
the willwood Front disc conversion uses the stock Drum Spindles and the cap is aluminum and screws onto the hub.. Here we go again.....
Re: Wilwood brake interferance with Magnum500 wheels [Re: tinman68] #695241
05/11/10 07:41 PM
05/11/10 07:41 PM
AndyF Offline
AndyF  Offline
No surprise there. Wilwood stuff is made for racing so the Wilwood engineers designed their hubs to work with racing rims like Centerlines. You're trying to get a dog and a cat to mate when you stick OEM steel rims on racing brakes.
Re: Wilwood brake interferance with Magnum500 wheels [Re: tinman68] #695242
05/11/10 08:36 PM
05/11/10 08:36 PM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
No Problem. Take the cap to a machine shop have it cut back to fit. Done it numerous times. So have friends of mine.
*** one time i had the outside grooved and left the center cap off. The word "wilwood" showed in the center. look good
Re: Wilwood brake interferance with Magnum500 wheels [Re: MAVERICKSHEMI] #695243
05/12/10 06:31 PM
05/12/10 06:31 PM
Bethlehem Pa.
tinman68 Offline OP
tinman68  Offline OP
Bethlehem Pa.
I figured it out. just remove willwood cap and install origional thin wall steel grease cap.
use a little sillicone sealent to hold it in place BINGO!!!!
thanks for your input.....
