I am in the process of changing wheels to Magnun500 for a more stock look from aluminum wheels.
the only interferance problem is the screw on WILLWOOD grease cap must be removed in order to install the wheel center caps. any suggestions.
the willwood Front disc conversion uses the stock Drum Spindles and the cap is aluminum and screws onto the hub.. Here we go again.....
