Re: making ss springs
[Re: kilroy]
#694617
05/12/10 10:53 PM
05/12/10 10:53 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I was thinking of reinstalling the sway bar I took off when
I installed my "caltrac"s this will be on the list of trials. thanks 3/8"? WOW that would definitely stiffen things.
You edited this post?? You installed "Caltracs"?
?? How fast are you going with the Charger.??
mike
[Re: Sport440]
#694618
05/12/10 11:23 PM
05/12/10 11:23 PM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
before I installed the aluminum heads, cam, and 4speed last winter I was at 8.3 in 1/8 at 85. Here is pic of my homemadeness. For give the body work.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Post deleted by Defbob
[Re: kilroy]
#694619
05/12/10 11:37 PM
05/12/10 11:37 PM
[Re: kilroy]
#694621
05/12/10 11:42 PM
05/12/10 11:42 PM
kilroy
Iowa State fan
on a different note... also countless hours of engineers and 32lbs of engineering work removed from my doors of my 73.
[Re: kilroy]
#694622
05/12/10 11:45 PM
05/12/10 11:45 PM
[Re: kilroy]
#694624
05/13/10 05:54 AM
05/13/10 05:54 AM
Posts: 52,972 Romeo MI
MR_P_BODY
know this has been asked but my understanding of spring rate... Set spring up side down (taking in account somehow for the friction on the floor) and measure weight to make spring drop and inch?
Normally this procedure is done with bearings on the ends to reduce the friction with a cyl/piston pressing down on the load point and is measured in pounds per inch did alot of them in the lab when I worked at Chrysler... I worked on the F & M bodies transverse torsion bar suspension when it was a pre proto set up.... hand bent MANY of those bars ![](/ubbthreads/images/graemlins/wave.gif)
