Re: making ss springs [Re: kilroy] #694617
05/12/10 10:53 PM
05/12/10 10:53 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I was thinking of reinstalling the sway bar I took off when
I installed my "caltrac"s this will be on the list of trials. thanks 3/8"? WOW that would definitely stiffen things.
You edited this post?? You installed "Caltracs"?
?? How fast are you going with the Charger.??
mike
Re: making ss springs [Re: Sport440] #694618
05/12/10 11:23 PM
05/12/10 11:23 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
before I installed the aluminum heads, cam, and 4speed last winter I was at 8.3 in 1/8 at 85. Here is pic of my homemadeness. For give the body work.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Post deleted by Defbob [Re: kilroy] #694619
05/12/10 11:37 PM
05/12/10 11:37 PM
Re: making ss springs *DELETED* #694620
05/12/10 11:39 PM
05/12/10 11:39 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Post deleted by kilroy
Re: making ss springs [Re: kilroy] #694621
05/12/10 11:42 PM
05/12/10 11:42 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
on a different note... also countless hours of engineers and 32lbs of engineering work removed from my doors of my 73.
Post deleted by Defbob [Re: kilroy] #694622
05/12/10 11:45 PM
05/12/10 11:45 PM
Re: making ss springs #694623
05/12/10 11:50 PM
05/12/10 11:50 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
? missed the pun. please explain
Re: making ss springs [Re: kilroy] #694624
05/13/10 05:54 AM
05/13/10 05:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
know this has been asked but my understanding of spring rate...
Set spring up side down (taking in account somehow for the friction on the floor) and measure weight to make spring drop and inch?
Normally this procedure is done with bearings on the
ends to reduce the friction with a cyl/piston pressing
down on the load point and is measured in pounds per inch
did alot of them in the lab when I worked at Chrysler...
I worked on the F & M bodies transverse torsion bar
suspension when it was a pre proto set up.... hand
bent MANY of those bars
