Best after market starter for BB #694272
05/10/10 05:51 PM
05/10/10 05:51 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Which is the best fitting after market starter for a 440/383 with Hooker competition headers?
i only want to take the headers off once to fit
CVR ?
we don't sell dodge pickups here so i can't buy a starter to suit
thanks,
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Best after market starter for BB [Re: tex013] #694273
05/12/10 12:47 PM
05/12/10 12:47 PM
Colorado
Scizmz Offline
Scizmz  Offline
Colorado
If I recall correctly the mini-starters are damn near universal. and SHOULD fit past your headers with little to no clearancing... *cough*
Re: Best after market starter for BB [Re: Scizmz] #694274
05/12/10 02:39 PM
05/12/10 02:39 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I've got one(factory mini from 92 1 ton van) on my 440 in my 86 RC.
Moparlee
Re: Best after market starter for BB [Re: Robbins] #694275
05/12/10 04:57 PM
05/12/10 04:57 PM
Kenosha, Wi
GOLDMYN Offline
GOLDMYN  Offline
Kenosha, Wi
either google or ebay D B Electrical for mini starter
Semper Fi
Re: Best after market starter for BB [Re: GOLDMYN] #694276
05/13/10 07:28 AM
05/13/10 07:28 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Mini. 440. TTI's. No problem.
Re: Best after market starter for BB [Re: tex013] #694277
05/13/10 01:27 PM
05/13/10 01:27 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
The problem with the factory mini starter is they stick outward from the block and some headers occupy this area.
The Rob MC starter can be rotated to any position. A little pricy but hopefully I will have it for a couple years or more before it needs to be serviced.
http://www.moparts.org/Tech/Archive/elec/2.html
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Best after market starter for BB [Re: HealthServices] #694278
05/13/10 01:46 PM
05/13/10 01:46 PM
So Cal
So Cal
Short mopar starter with the stupid headman header
Below is the same tube with the mc starter!
Rear shot in the 1 o’clock position
Even at the 3 o’clock position there is more room than the stock mini starter!
5 o’clock position
Edit: June 21 I resized the pics so it won't be so hard to read this post.
Re: Best after market starter for BB [Re: tex013] #694279
05/13/10 09:28 PM
05/13/10 09:28 PM
NY
W
WICKD6PK Offline
WICKD6PK  Offline
W
NY
RobbMc starter a little pricey but well worth the extra $ fits great- lots of room
Re: Best after market starter for BB [Re: WICKD6PK] #694280
05/14/10 02:07 AM
05/14/10 02:07 AM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
Thank you for posting the photos Health. By using planetary gear reduction rather than offset reduction, we can keep the motor very close to the block.
HOWEVER, please keep in mind, our starter will not clear some aftermarket blocks (such as Indy Max or World Products) when using a 130 tooth ring gear (all automatics and some manual trans) because the blocks are wider in the starter area.
Designing a better mouse trap always seems to lead to the evolution of smarter mice. www.robbmcperformance.com
Re: Best after market starter for BB [Re: RobbMc] #694281
06/21/10 09:11 PM
06/21/10 09:11 PM
North Dakota
440abody Offline
440abody  Offline
North Dakota
O.K. maybe I'm reading this wrong, but what I gather from this is that it will NOT fit my 727?
73 Dart Swinger 440/727 8.75 w/3.55's
34 Ford 3w coupe with a soon to be 1958 392HEMI!
Re: Best after market starter for BB [Re: 440abody] #694282
06/21/10 09:17 PM
06/21/10 09:17 PM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
Not if you are using an Indy or WP block. Otherwise, yes.
Re: Best after market starter for BB [Re: tex013] #694283
06/21/10 11:47 PM
06/21/10 11:47 PM
CT
440Kilmartin Offline
CT
Hello I'm 19 and recently bought my first muscle car. its a 69 roadrunner 440 4 speed w/ a dana. it has headers and i noticed the original style starter is touching the header. .Do you think i should change the starter or the headers or both. and what brands. Thank you
383man [Re: 440Kilmartin] #694284
06/22/10 12:17 AM
06/22/10 12:17 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use the Mopar starter on my sons 400 and I bought a "Power Master" starter for the 440 in my 63. Both work great. The Dart has 2" CPPA headers and my 63 has 1-3/4 Hedmans. Ron
Re: Best after market starter for BB [Re: 440Kilmartin] #694285
06/22/10 12:27 AM
06/22/10 12:27 AM
So Cal
So Cal
Depends on what you want, but if your starter has been resting on the header for a while, it is ready to die anyways, so putting on a new header that clears that old starter will still mean you have a old starter that's has been subject to a lot of heat.
In other words if you buy a new header you should buy a new starter too. If you buy the correct starter for your application, you will have less headaches.
Boy I'm going to repost the pictures so this post is not so awkward to read.
The following 5 pictures are repost so I will not have to host them. Please disregard as they are posted above. sorry.
Re: Best after market starter for BB [Re: HealthServices] #694286
06/22/10 12:49 AM
06/22/10 12:49 AM
So Cal
So Cal
Short starter with Headman header...
Re: Best after market starter for BB [Re: HealthServices] #694287
06/22/10 12:55 AM
06/22/10 12:55 AM
So Cal
So Cal
Same RobbMC starter with same tube
Re: Best after market starter for BB [Re: HealthServices] #694288
06/22/10 12:57 AM
06/22/10 12:57 AM
So Cal
So Cal
robbmc Solenoid in 1 o'clock position
Re: Best after market starter for BB [Re: HealthServices] #694289
06/22/10 01:02 AM
06/22/10 01:02 AM
So Cal
So Cal
3 o'clock position with room still to spare.
Re: Best after market starter for BB [Re: HealthServices] #694290
06/22/10 01:05 AM
06/22/10 01:05 AM
So Cal
So Cal
5 o'clock position
Re: Best after market starter for BB [Re: HealthServices] #694291
06/22/10 01:27 AM
06/22/10 01:27 AM
So Cal
So Cal
Member 'Stinger' factory style mini starter hitting exhaust.
From below
From above
Slight dinging required for this header...
