Best after market starter for BB
#694272
05/10/10 05:51 PM
05/10/10 05:51 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
Which is the best fitting after market starter for a 440/383 with Hooker competition headers? i only want to take the headers off once to fit CVR ? we don't sell dodge pickups here so i can't buy a starter to suit thanks, Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Best after market starter for BB
[Re: Scizmz]
#694274
05/12/10 02:39 PM
05/12/10 02:39 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I've got one(factory mini from 92 1 ton van) on my 440 in my 86 RC.
Moparlee
[Re: tex013]
#694277
05/13/10 01:27 PM
05/13/10 01:27 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
The problem with the factory mini starter is they stick outward from the block and some headers occupy this area. The Rob MC starter can be rotated to any position. A little pricy but hopefully I will have it for a couple years or more before it needs to be serviced. http://www.moparts.org/Tech/Archive/elec/2.html
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: 440abody]
#694282
06/21/10 09:17 PM
06/21/10 09:17 PM
Posts: 961 Carson City, Nevada
RobbMc
Carson City, Nevada
O.K. maybe I'm reading this wrong, but what I gather from this is that it will NOT fit my 727?
Not if you are using an Indy or WP block. Otherwise, yes.
[Re: HealthServices]
#694286
06/22/10 12:49 AM
06/22/10 12:49 AM
Posts: 7,759 So Cal
HealthServices
So Cal
Short starter with Headman header...
Allen
#694287
06/22/10 12:55 AM
06/22/10 12:55 AM
Posts: 7,759 So Cal
HealthServices
So Cal
Same RobbMC starter with same tube
Allen
#694288
06/22/10 12:57 AM
06/22/10 12:57 AM
Posts: 7,759 So Cal
HealthServices
So Cal
robbmc Solenoid in 1 o'clock position
Allen
#694289
06/22/10 01:02 AM
06/22/10 01:02 AM
Posts: 7,759 So Cal
HealthServices
So Cal
3 o'clock position with room still to spare.
Allen
#694291
06/22/10 01:27 AM
06/22/10 01:27 AM
Posts: 7,759 So Cal
HealthServices
So Cal
Member 'Stinger' factory style mini starter hitting exhaust. From below From above Slight dinging required for this header...
Allen
