Comp Pro Magnum rockers ?
#694037
05/10/10 03:48 PM
05/10/10 03:48 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I have read about these rockers being a problem with bigger cams and higher spring pressures. Is anyone using them with a milder hydraulic or solid lifter FT cam? The cam I am going to use is a Comp Cams XE284. I have these mocked up and ready to use, but I am having concerns. I really don't want to spend the bucks to have them bushed if I don't have to.
Thanks, Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Comp Pro Magnum rockers ?
[Re: Hemi Allstate]
#694039
05/10/10 03:50 PM
05/10/10 03:50 PM
Thumperdart
State of confusion
I ran em for 5+ years w/a solid cam and had zero issues and as far as I know, they`re still going strong.
[Re: Hemi Allstate]
#694042
05/10/10 04:31 PM
05/10/10 04:31 PM
Thumperdart
State of confusion
The cam was a solid Isky w/.590-.605 lift and the dur. was somewhere around 260 @.050 I think.
[Re: Hemi Allstate]
#694044
05/10/10 05:19 PM
05/10/10 05:19 PM
Posts: 84 NC
Badfish67
NC
Let me tell you about my issues with the Pro Magnum rockers. I had them on my small block with a .670 lift solid roller cam and 260ish seat pressure. The rockers galled the shafts and from that I bent a few valves. The rockers suck and i'll never use them even on a street engine. I know ya'll going to say that I should not have used them with my cam and springs, but Comp and Indy said I would be fine. Now the engine is at RyanJ's shop and I cant wait to get it back!!!
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: Hemi Allstate]
#694046
05/10/10 05:46 PM
05/10/10 05:46 PM
Posts: 17,884 S.E. Michigan
ZIPPY
S.E. Michigan
You won't have any problems with them if everything is set up correctly. It should be fine.
I haven't any issues with them at 500lbs open pressure without any bushings or honing.
Use/create Comp's recommended .030" side clearance, use a liquid assembly lube or oil (not thick paste), and whatever you do...don't overtorque the shafts.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#694049
05/10/10 06:14 PM
05/10/10 06:14 PM
Hemi Allstate
Mt. Eden Ky.
Sounds like I have it right except that I used Lubriplate assembly lube on the shafts? Is that a problem? Thanks, Mark
[Re: Hemi Allstate]
#694050
05/10/10 06:26 PM
05/10/10 06:26 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
They work great until you get over 500 lbs of spring pressure... more pressure, the quicker they will gall.
Have had a bunch of customers not listen to me & end up galling their Pro Mags on Solid Rollers. Nice to know Comp is now bushing them...
PRW Chrome Molys are an almost exact copy of the Pro Mags, & have a thick bronze bushing in them... Alot less $, more choices of rocker ratios...(Pro Mags only 1.5) only problem is the adjusters are brittle. I just went over 8000 miles this morning on my PRW's on my 440, mild street solid roller, 190 seat, 550 open. I put T&D adjusters in them... been great rockers other than the adjuster issue.
