Comp Pro Magnum rockers ? #694037
05/10/10 03:48 PM
05/10/10 03:48 PM
Mt. Eden Ky.
Hemi Allstate Offline OP
Mt. Eden Ky.
I have read about these rockers being a problem with bigger cams and higher spring pressures. Is anyone using them with a milder hydraulic or solid lifter FT cam?
The cam I am going to use is a Comp Cams XE284.
I have these mocked up and ready to use, but I am having concerns. I really don't want to spend the bucks to have them bushed if I don't have to.
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Comp Pro Magnum rockers ? [Re: Hemi Allstate] #694038
05/10/10 03:50 PM
05/10/10 03:50 PM
AndyF Offline
AndyF  Offline
They should be fine with a flat tappet cam. The new rocker arms from Comp are bushed so evidently the engineers decided to make the switch.
Re: Comp Pro Magnum rockers ? [Re: Hemi Allstate] #694039
05/10/10 03:50 PM
05/10/10 03:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I ran em for 5+ years w/a solid cam and had zero issues and as far as I know, they`re still going strong.
Re: Comp Pro Magnum rockers ? [Re: AndyF] #694040
05/10/10 04:01 PM
05/10/10 04:01 PM
Mt. Eden Ky.
Mt. Eden Ky.
Thanks Andy,
BTW I bought your book and I am enjoying reading it.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Comp Pro Magnum rockers ? [Re: Thumperdart] #694041
05/10/10 04:03 PM
05/10/10 04:03 PM
Mt. Eden Ky.
Mt. Eden Ky.
I ram em for 5+ years w/a solid cam and had zero issues and as far as I know, they`re still going strong.
Thanks Thumper,
How big of a solid cam did you use with these rockers?
This is a 470 inch BTW. A lot tammer than yours though!
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Comp Pro Magnum rockers ? [Re: Hemi Allstate] #694042
05/10/10 04:31 PM
05/10/10 04:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The cam was a solid Isky w/.590-.605 lift and the dur. was somewhere around 260 @.050 I think.
Re: Comp Pro Magnum rockers ? [Re: Thumperdart] #694043
05/10/10 04:55 PM
05/10/10 04:55 PM
Mt. Eden Ky.
Mt. Eden Ky.
Well that sounds reassuring! Leaves a lot of room to grow!
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Comp Pro Magnum rockers ? [Re: Hemi Allstate] #694044
05/10/10 05:19 PM
05/10/10 05:19 PM
NC
Badfish67 Offline
Badfish67  Offline
NC
Let me tell you about my issues with the Pro Magnum rockers.
I had them on my small block with a .670 lift solid roller cam and 260ish seat pressure. The rockers galled the shafts and from that I bent a few valves. The rockers suck and i'll never use them even on a street engine.
I know ya'll going to say that I should not have used them with my cam and springs, but Comp and Indy said I would be fine.
Now the engine is at RyanJ's shop and I cant wait to get it back!!!
1967 Barracuda 360ci/727 9.723ET @139.44mph
Re: Comp Pro Magnum rockers ? [Re: Badfish67] #694045
05/10/10 05:44 PM
05/10/10 05:44 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I ran the Comp SB rockers 125 passes. Rotella-T 15W-40,
Shubeck lifters and 440+ lbs. open pressure.
They looked better than I expected.
Re: Comp Pro Magnum rockers ? [Re: Hemi Allstate] #694046
05/10/10 05:46 PM
05/10/10 05:46 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
You won't have any problems with them if everything is set up correctly. It should be fine.
I haven't any issues with them at 500lbs open pressure without any bushings or honing.
Use/create Comp's recommended .030" side clearance, use a liquid assembly lube or oil (not thick paste), and whatever
you do...don't overtorque the shafts.
Rich H.
Esse Quam Videri
Re: Comp Pro Magnum rockers ? [Re: Badfish67] #694047
05/10/10 05:49 PM
05/10/10 05:49 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
You ran $450 rockers with a 670 lift solid roller? they work fine for street type stuff
Re: Comp Pro Magnum rockers ? [Re: S/ST 3040] #694048
05/10/10 05:51 PM
05/10/10 05:51 PM
S/ST 3040 Offline
S/ST 3040  Offline
Re: Comp Pro Magnum rockers ? [Re: ZIPPY] #694049
05/10/10 06:14 PM
05/10/10 06:14 PM
Mt. Eden Ky.
Mt. Eden Ky.
Sounds like I have it right except that I used Lubriplate assembly lube on the shafts? Is that a problem?
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Comp Pro Magnum rockers ? [Re: Hemi Allstate] #694050
05/10/10 06:26 PM
05/10/10 06:26 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
They work great until you get over 500 lbs of spring pressure... more pressure, the quicker they will gall.
Have had a bunch of customers not listen to me & end up galling their Pro Mags on Solid Rollers. Nice to know Comp is now bushing them...
PRW Chrome Molys are an almost exact copy of the Pro Mags, & have a thick bronze bushing in them... Alot less $, more choices of rocker ratios...(Pro Mags only 1.5) only problem is the adjusters are brittle. I just went over 8000 miles this morning on my PRW's on my 440, mild street solid roller, 190 seat, 550 open. I put T&D adjusters in them... been great rockers other than the adjuster issue.
Re: Comp Pro Magnum rockers ? [Re: Hemi Allstate] #694051
05/13/10 09:19 AM
05/13/10 09:19 AM
S.E. Michigan
S.E. Michigan
Thanks,
Mark
Lubriplate should be thin enough to wash away fairly quick. As usual prime with the valve covers off, watch everything....whenever possible you want oil flowing through there as opposed to great globs of greasey gunk clogging everything up (exaggerating a bit there).
Rich H.
Esse Quam Videri
Re: Comp Pro Magnum rockers ? [Re: ZIPPY] #694052
05/13/10 09:33 AM
05/13/10 09:33 AM
Mt. Eden Ky.
Mt. Eden Ky.
Thanks,
Mark
Thanks Zippy!
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Comp Pro Magnum rockers ? [Re: Hemi Allstate] #694053
05/13/10 08:42 PM
05/13/10 08:42 PM
OH, USA
Torred Offline
Torred  Offline
OH, USA
I use the Comp Pro Magnum Rockers on a 440 with
COMP Cams XE 284 cam
COMP Cams P/N #911-16 Single Outer Valve Spring; 1.524" (with Damper)
COMP Cams P/N #867-16 Pro Magnum Hydraulic Lifters
Going on 5 years Street/Strip no problems, no complaints but I believe that the springs are considered marginal for my application.
Re: Comp Pro Magnum rockers ? [Re: Torred] #694054
05/14/10 12:35 PM
05/14/10 12:35 PM
Mt. Eden Ky.
Mt. Eden Ky.
Thanks for your input. I am using the springs that came with the Edelbrock heads and I don't know how they compare to the Comps?
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Comp Pro Magnum rockers ? [Re: Hemi Allstate] #694055
05/14/10 01:40 PM
05/14/10 01:40 PM
Up in the North and Far Away
AutoEngineer Offline
How do they feed oil to the pushrod cup and adjuster ball?
Is there an oil passage through the rocker body?
Re: Comp Pro Magnum rockers ? [Re: AutoEngineer] #694056
05/14/10 01:56 PM
05/14/10 01:56 PM
Mt. Eden Ky.
Mt. Eden Ky.
Yes, there is and oil flows directly to the cup.
1996 Ram 1500 Sport
1968 road runner
