452 Cast head fluid leak? #691133
05/07/10 01:49 PM
05/07/10 01:49 PM
Long Island, NY.
Stroked65Belv Offline OP
Long Island, NY.
I loosened the header bolts on my 452 cast iron heads today and coolant came out! I dont remember this being good nor supposed to occur.Not sure if the exhaust manifold bolts/studs got into the coolant jackets.
Anyone have an opinion here to assist me? Looks like the summer cruising isnt going to happpen. Unless I can find a simple fix.
Re: 452 Cast head fluid leak? [Re: Stroked65Belv] #691134
05/07/10 02:00 PM
05/07/10 02:00 PM
Hemiroid Offline
Hemiroid  Offline
You're ok! A few are in the water from the factory
Re: 452 Cast head fluid leak? [Re: Hemiroid] #691135
05/07/10 02:03 PM
05/07/10 02:03 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Generally the end holes are tapped into the water jackets.
Re: 452 Cast head fluid leak? [Re: Hemiroid] #691136
05/07/10 02:07 PM
05/07/10 02:07 PM
Long Island, NY.
Long Island, NY.
Thanks Hemiroid! I really appreciate the help on that one. Been a while (years!) since I have done this. What would you recommend as for putting on the new bolts for sealant? I have some Permatex-pneumatic/hydraulic sealant that I have used before with no issues but it wasnt heated like this will be on exhaust ports?
Re: 452 Cast head fluid leak? [Re: B G Racing] #691137
05/07/10 02:09 PM
05/07/10 02:09 PM
Long Island, NY.
Long Island, NY.
Thanks as well B G... That is where I found the coolant, on both ends of the right head.
Re: 452 Cast head fluid leak? [Re: Stroked65Belv] #691138
05/07/10 02:27 PM
05/07/10 02:27 PM
Hemiroid Offline
Hemiroid  Offline
I just use a little high temp silicone and have never had a problem.
Re: 452 Cast head fluid leak? [Re: Stroked65Belv] #691139
05/07/10 05:28 PM
05/07/10 05:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
As stated, the outer bolt holes go into water and if you can, I`d put studs in those w/sealant instead of bolts if it doesn`t jack up installing/removing the headers/maniolds.
Re: 452 Cast head fluid leak? [Re: Stroked65Belv] #691140
05/13/10 01:05 PM
05/13/10 01:05 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Just an FYI ALL Big Block stock iron heads exh bolt holes are WET , only the stock iron small blocks are wet on the end holes ...
Re: 452 Cast head fluid leak? [Re: JohnRR] #691141
05/15/10 10:01 AM
05/15/10 10:01 AM
Long Island, NY.
Long Island, NY.
Thanks John, I lubed all the holes with sealant. I appreciate the help guys!
Re: 452 Cast head fluid leak? [Re: Stroked65Belv] #691142
05/15/10 12:03 PM
05/15/10 12:03 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I hope you used Hi-Temp RTV. I tried PTFE(teflon) once, and the engine warmed up fine the first time, then leaked when I warmed it a second time.....takes a little time, but it melts out.
Yeah, it's got a smallblock.
