Re: 452 Cast head fluid leak?
[Re: Stroked65Belv]
#691139
05/07/10 05:28 PM
05/07/10 05:28 PM
Thumperdart
State of confusion
As stated, the outer bolt holes go into water and if you can, I`d put studs in those w/sealant instead of bolts if it doesn`t jack up installing/removing the headers/maniolds.
[Re: Stroked65Belv]
#691142
05/15/10 12:03 PM
05/15/10 12:03 PM
Posts: 1,532 off the grid
340B5
off the grid
I hope you used Hi-Temp RTV. I tried PTFE(teflon) once, and the engine warmed up fine the first time, then leaked when I warmed it a second time.....takes a little time, but it melts out.
Yeah, it's got a smallblock.
