Another "what will it run?" post UPDATE! New Best!
#689709
05/05/10 06:53 PM
05/05/10 06:53 PM
Posts: 834 Beavercreek, Ohio
OA5599
Beavercreek, Ohio
69 Cuda with 8.5:1 340/727
3.91s
RPM intake
750 Holley
stock J heads
Hughes Whiplash cam
Intake Valve Lift 1.5 Exhaust Valve Lift 1.5 .512" .518" Intake Valve Lift 1.6 Exhaust Valve Lift 1.6 .546" .552" Intake Duration at .050" Exhaust Duration at .050" 223° 236° Lobe Separation Angle 107º Intake Opening at .050" Exhaust Opening at .050" 7.5° BTC 48° BBC Intake Closing at .050" Exhaust Closing at .050" 35.5° ABC 8° ATC
Last year at the Classics it ran a best of 13.26 @ 103 with a stock converter and 215/70/14 rear tires. 60 ft times were 2.0s at best. This year it has a tight 10" converter and 275/50/15 M/T drag radials. With that cam and converter combo and hooking up hard, what kind of gains do you think I could expect at the Classics in a couple of weeks? Not looking for exact, this is just for fun. 13.10s? 13.00? 12.9?
What do you think?
Re: Another "what will it run?" post
[Re: S/ST 3040]
#689714
05/05/10 10:02 PM
05/05/10 10:02 PM
OA5599
Beavercreek, Ohio
Depending on the weather but, I'll say 12.90 @ 104 MPH Doesn't that car weigh like 3400+ lbs?
Last year it weighed 3440 with a full tank of fuel, spare tire, and jack. Driver weighed 140lbs. This year, the spare tire and jack are removed. The back seat will also be out for the Classics while it's being reupholstered. However, the wheels are now 15" instead of 14" and the tires are wider, so that added a few pounds. Tires are within a 10th of an inch of the last year's, so gear ratio will be about the same.
[Re: OA5599]
#689718
05/06/10 08:11 PM
05/06/10 08:11 PM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
Those are no small changes. How much weight is that? Weather conditions play a big part when trying to compare results as well.
I'll guess 12.93 @ 104.5.
[Re: OA5599]
#689722
05/08/10 03:00 PM
05/08/10 03:00 PM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
I know I gained 2 tenths when I went to a sticky tire and also agree what comes off of your 60' so goes the e.t.. Assuming the converter is an upgrade, stalls better and is more efficient through the traps.............. I'd say bustin' into the 12.90's (or better) is no problem.
[Re: Dodgem]
#689726
05/14/10 10:33 PM
05/14/10 10:33 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
You can look at that either way.... Either he's not MPHing real well, OR.... Damn!, he's getting out of the hole quick for a car that only goes 103!!! My car ran 13.7's at 101 last year.
[Re: StealthWedge67]
#689727
05/15/10 12:08 AM
05/15/10 12:08 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I run 12.5s @ 104, soon to be 12.4s Congrats on the new best, get that 60ft. down & it'll be in the 12s.
