Another "what will it run?" post UPDATE! New Best! #689709
05/05/10 06:53 PM
05/05/10 06:53 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
69 Cuda with 8.5:1 340/727
3.91s
RPM intake
750 Holley
stock J heads
Hughes Whiplash cam
Intake Valve Lift 1.5
Exhaust Valve Lift 1.5 .512"
.518"
Intake Valve Lift 1.6
Exhaust Valve Lift 1.6 .546"
.552"
Intake Duration at .050"
Exhaust Duration at .050" 223°
236°
Lobe Separation Angle 107º
Intake Opening at .050"
Exhaust Opening at .050" 7.5° BTC
48° BBC
Intake Closing at .050"
Exhaust Closing at .050" 35.5° ABC
8° ATC
Last year at the Classics it ran a best of 13.26 @ 103 with a stock converter and 215/70/14 rear tires. 60 ft times were 2.0s at best. This year it has a tight 10" converter and 275/50/15 M/T drag radials. With that cam and converter combo and hooking up hard, what kind of gains do you think I could expect at the Classics in a couple of weeks? Not looking for exact, this is just for fun. 13.10s? 13.00? 12.9?
What do you think?
Re: Another "what will it run?" post [Re: OA5599] #689710
05/05/10 09:38 PM
05/05/10 09:38 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
12.85
Re: Another "what will it run?" post [Re: OA5599] #689711
05/05/10 09:44 PM
05/05/10 09:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Depends on the conv but 12.60s
Re: Another "what will it run?" post [Re: OA5599] #689712
05/05/10 09:52 PM
05/05/10 09:52 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Depending on the weather but, I'll say 12.90 @ 104 MPH
Doesn't that car weigh like 3400+ lbs?
Re: Another "what will it run?" post [Re: OA5599] #689713
05/05/10 10:02 PM
05/05/10 10:02 PM
MotorCity
RC91 Offline
RC91  Offline
MotorCity
From my personal experience, a 10th off the 60ft times equals a 10th and a half off the ET. So, if the converter and drag radials get you down to a 1.75 60ft, I'd say 12.85 or so.
Re: Another "what will it run?" post [Re: S/ST 3040] #689714
05/05/10 10:02 PM
05/05/10 10:02 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
Last year it weighed 3440 with a full tank of fuel, spare tire, and jack. Driver weighed 140lbs. This year, the spare tire and jack are removed. The back seat will also be out for the Classics while it's being reupholstered. However, the wheels are now 15" instead of 14" and the tires are wider, so that added a few pounds. Tires are within a 10th of an inch of the last year's, so gear ratio will be about the same.
Re: Another "what will it run?" post [Re: OA5599] #689715
05/06/10 11:49 AM
05/06/10 11:49 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I'll guess 12.90
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Another "what will it run?" post [Re: OA5599] #689716
05/06/10 12:24 PM
05/06/10 12:24 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I thing 12.6's 12.7's for sure.
Re: Another "what will it run?" post [Re: Dodgem] #689717
05/06/10 05:30 PM
05/06/10 05:30 PM
Clinton Twp, Michigan
DerickS Offline
DerickS  Offline
12.80
Re: Another "what will it run?" post [Re: OA5599] #689718
05/06/10 08:11 PM
05/06/10 08:11 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Those are no small changes. How much weight is that? Weather conditions play a big part when trying to compare results as well.
I'll guess 12.93 @ 104.5.
Re: Another "what will it run?" post [Re: OA5599] #689719
05/06/10 08:50 PM
05/06/10 08:50 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I ran my first 12.9 pass on 103 MPH...when you hook you may lose some MPH but the weight loss and good converter should more than make up for it.
Re: Another "what will it run?" post [Re: dustergirl340] #689720
05/06/10 09:00 PM
05/06/10 09:00 PM
Tennessee
727builder Offline
727builder  Offline
Tennessee
Good lookin car.
12.99 @ 104
Re: Another "what will it run?" post [Re: OA5599] #689721
05/08/10 02:47 PM
05/08/10 02:47 PM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
These guys are really being optimistic, i like that, that will be a time slip for the laminator.
Re: Another "what will it run?" post [Re: OA5599] #689722
05/08/10 03:00 PM
05/08/10 03:00 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I know I gained 2 tenths when I went to a sticky tire and also agree what comes off of your 60' so goes the e.t.. Assuming the converter is an upgrade, stalls better and is more efficient through the traps..............
I'd say bustin' into the 12.90's (or better) is no problem.
Re: Another "what will it run?" post [Re: Dean_Kuzluzski] #689723
05/08/10 04:59 PM
05/08/10 04:59 PM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
We are likin the sounds of that.
Re: Another "what will it run?" post [Re: Lew] #689724
05/14/10 05:50 PM
05/14/10 05:50 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
The air wasn't the greatest today, but 13.16 @ 103. Red light first round in the gambler's race, but would have broke out anyway. Best 60ft was 1.89 on the last run. Hoping for better air during time trials in the morning...and maybe a 12.9 or so. Either way, great first day.
Re: Another "what will it run?" post [Re: OA5599] #689725
05/14/10 08:58 PM
05/14/10 08:58 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
your not MPHing real good how is your jetting too rick or too lean can kill it!!
Re: Another "what will it run?" post [Re: Dodgem] #689726
05/14/10 10:33 PM
05/14/10 10:33 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
You can look at that either way.... Either he's not MPHing real well, OR.... Damn!, he's getting out of the hole quick for a car that only goes 103!!! My car ran 13.7's at 101 last year.
Re: Another "what will it run?" post [Re: StealthWedge67] #689727
05/15/10 12:08 AM
05/15/10 12:08 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I run 12.5s @ 104, soon to be 12.4s
Congrats on the new best, get that 60ft. down & it'll be in the 12s.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Another "what will it run?" post [Re: OA5599] #689728
05/15/10 07:19 AM
05/15/10 07:19 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Pretty good air this morning, at least in western PA. Let us know how it goes.
