torsion bar issues? (UPDATED with pics now)
#68910
06/06/08 10:16 PM
06/06/08 10:16 PM
Posts: 5,037 hi
sharpie
Moparts Linguist
Moparts Linguist
hi
Because I re-did my front end, I had to unload my torison bars. Well, after I got everything buttoned up, I cranked the torsion bars up again. I got the car pretty high up, too far actually, and then brought them down to a pretty low front ride height.
Because the tire was very close (1/8") from the wheelwell, I cranked it up just a bit. I jounced the car multiple times to "settle" it, and it seemed to stay in the right place.
To test the brakes, I took it around the block, and upon returning, I noticed that the ride height sank right back down to 1/8" from the tires. I looked under the car, and the adjusting bolts were where they were prior to the sinking.
And so yesterday, I cranked the adjusting bolt clockwise again to bring the height up. It looked fine, even after a good thorough jouncing, but again right after taking it around the block just once, maybe 1 minute of driving, I could see and feel the suspension sink again. The adjusting bolt again didn't back out, but I am really confused. Any ideas? TIA
Re: torsion bar issues?
[Re: BDW]
#68913
06/07/08 11:03 AM
06/07/08 11:03 AM
RapidRobert
Brian crank them up higher then you want them & do it again.
[Re: charger RTSE]
#68915
06/07/08 11:35 AM
06/07/08 11:35 AM
Posts: 5,037 hi
sharpie
Moparts Linguist
Moparts Linguist
hi
Check that the end of the adjustment bolt is seated corectly in the groove where it is suposed to go.
Will do.
I have found that for every one complete turn of the adjustment bolt you gain a half inch in heigth.
I cranked them about seven threads each time, and every time I drove it, it settled back to a place where I literally couldn't notice a difference from where it was before I started, if that makes any sense.
I did, which is why I am so perplexed. I actually have a picture or two:
I started here:
and after a single trip around the block, it went down to:
So then I increased height again to the first picture, and it settled right back down to the second picture with no noticeable height difference from before increasing height the second time.
[Re: sharpie]
#68916
06/07/08 11:41 AM
06/07/08 11:41 AM
Posts: 1,037 Texas, Dallas
G_T
Texas, Dallas
Get under the car and check the torsion bar attachment points. I've seen one case where the welds on one of the rear attachment points broke and the whole deal could turn in frame. Case of rot. I highly doubt this is it - but check both end.
By now you should be running out of adjustment on the bolts. Is the adjustment bolt fully seated yet - and/or is the adjustment cam/arm really cranked over?
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com
2012 Charger SRT8
[Re: stumpy]
#68919
06/08/08 02:16 AM
06/08/08 02:16 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
No way a car should drop that far. You got a major problemm somewhere. Check the torsion bar mounts like was said.
It will with too much toe-in. I've seen it. Once we got the toe adjusted properly it stopped sucking the front end down.
[Re: stumpy]
#68921
06/09/08 02:02 PM
06/09/08 02:02 PM
Posts: 7,369 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
That is my guess. An easy way to check this is to use a greese pensil(or crayon) and mark the torsion bar socket and the frame. Drive the car around the block and make sure your marks still line up. If they don't, the socket is spinning in the frame. Good luck!
[Re: stumpy]
#68923
06/09/08 03:36 PM
06/09/08 03:36 PM
Posts: 780 Woodinville, WA
Viol8r
Woodinville, WA
I agree, major problems. Your bars must be spinning in there mounts taking tension out while you drive. I have never seen a front end that high!
[Re: sharpie]
#68924
06/09/08 04:12 PM
06/09/08 04:12 PM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
Dude,
Mine do the same thing. I set the car up, go drive it, park it, get back in it and it is on th ground. Looks cool, but damn is it low.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
[Re: charger RTSE]
#68926
06/10/08 08:02 AM
06/10/08 08:02 AM
70Coronet500Vert
St Charles MO
I did not, well, which is the left side of the car?
Also, I have been drivign mine 2 yrs this way and I figure they would have snapped by now if they were on the wrong side.....
