Page 1 of 3 1 2 3
torsion bar issues? (UPDATED with pics now) #68910
06/06/08 10:16 PM
06/06/08 10:16 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Because I re-did my front end, I had to unload my torison bars. Well, after I got everything buttoned up, I cranked the torsion bars up again. I got the car pretty high up, too far actually, and then brought them down to a pretty low front ride height.
Because the tire was very close (1/8") from the wheelwell, I cranked it up just a bit. I jounced the car multiple times to "settle" it, and it seemed to stay in the right place.
To test the brakes, I took it around the block, and upon returning, I noticed that the ride height sank right back down to 1/8" from the tires. I looked under the car, and the adjusting bolts were where they were prior to the sinking.
And so yesterday, I cranked the adjusting bolt clockwise again to bring the height up. It looked fine, even after a good thorough jouncing, but again right after taking it around the block just once, maybe 1 minute of driving, I could see and feel the suspension sink again. The adjusting bolt again didn't back out, but I am really confused. Any ideas? TIA
Re: torsion bar issues? [Re: sharpie] #68911
06/07/08 08:40 AM
06/07/08 08:40 AM
Australia
charger RTSE Offline
Australia
Check that the end of the adjustment bolt is seated corectly in the groove where it is suposed to go.
Re: torsion bar issues? [Re: charger RTSE] #68912
06/07/08 08:59 AM
06/07/08 08:59 AM
BDW Offline
BDW  Offline
Not sure how much you adjusted it, but some settling is normal. I just rebuilt my front end and had same issue. With everthing new it didn't settle until after driving. It would sit higher when lowered from floor jack. Had to drive it after each adjustment to get the right ride height.
Given all that, it should raise the front-end if you tighten the adjuster. Just hard to tell the exact amount until you drive it a few miles.
Re: torsion bar issues? [Re: BDW] #68913
06/07/08 11:03 AM
06/07/08 11:03 AM
Brian crank them up higher then you want them & do it again.
Re: torsion bar issues? [Re: RapidRobert] #68914
06/07/08 11:05 AM
06/07/08 11:05 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I have found that for every one complete turn of the adjustment bolt you gain a half inch in heigth.
Re: torsion bar issues? [Re: charger RTSE] #68915
06/07/08 11:35 AM
06/07/08 11:35 AM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Will do.
I cranked them about seven threads each time, and every time I drove it, it settled back to a place where I literally couldn't notice a difference from where it was before I started, if that makes any sense.
I did, which is why I am so perplexed. I actually have a picture or two:
I started here:
and after a single trip around the block, it went down to:
So then I increased height again to the first picture, and it settled right back down to the second picture with no noticeable height difference from before increasing height the second time.
Re: torsion bar issues? [Re: sharpie] #68916
06/07/08 11:41 AM
06/07/08 11:41 AM
Texas, Dallas
G_T Offline
G_T  Offline
Texas, Dallas
Get under the car and check the torsion bar attachment points. I've seen one case where the welds on one of the rear attachment points broke and the whole deal could turn in frame. Case of rot. I highly doubt this is it - but check both end.
By now you should be running out of adjustment on the bolts. Is the adjustment bolt fully seated yet - and/or is the adjustment cam/arm really cranked over?
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
Re: torsion bar issues? [Re: G_T] #68917
06/07/08 04:04 PM
06/07/08 04:04 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Your toe may be off. If the toe is set too far in it will suck the front end down when you drive it. Make sure the alignment is set properly.
Re: torsion bar issues? [Re: Jim_Lusk] #68918
06/07/08 06:25 PM
06/07/08 06:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No way a car should drop that far. You got a major problemm somewhere. Check the torsion bar mounts like was said.
Re: torsion bar issues? [Re: stumpy] #68919
06/08/08 02:16 AM
06/08/08 02:16 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It will with too much toe-in. I've seen it. Once we got the toe adjusted properly it stopped sucking the front end down.
Re: torsion bar issues? [Re: Jim_Lusk] #68920
06/08/08 10:58 AM
06/08/08 10:58 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
To do that with toe in the tires would almost have to be pointing at each other.
Re: torsion bar issues? [Re: stumpy] #68921
06/09/08 02:02 PM
06/09/08 02:02 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
That is my guess. An easy way to check this is to use a greese pensil(or crayon) and mark the torsion bar socket and the frame. Drive the car around the block and make sure your marks still line up. If they don't, the socket is spinning in the frame. Good luck!
Re: torsion bar issues? [Re: burdar] #68922
06/09/08 02:08 PM
06/09/08 02:08 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I agree with Jim, bach up and see if it comes back up
Mitch
Re: torsion bar issues? [Re: stumpy] #68923
06/09/08 03:36 PM
06/09/08 03:36 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
I agree, major problems. Your bars must be spinning in there mounts taking tension out while you drive. I have never seen a front end that high!
Re: torsion bar issues? [Re: sharpie] #68924
06/09/08 04:12 PM
06/09/08 04:12 PM
St Charles MO
70Coronet500Vert Offline
St Charles MO
Dude,
Mine do the same thing. I set the car up, go drive it, park it, get back in it and it is on th ground. Looks cool, but damn is it low.
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: torsion bar issues? [Re: 70Coronet500Vert] #68925
06/10/08 06:33 AM
06/10/08 06:33 AM
Australia
Australia
When you pulled the front end appart you didnt mix up the bars they are marked on the ends L left R right.
Re: torsion bar issues? [Re: charger RTSE] #68926
06/10/08 08:02 AM
06/10/08 08:02 AM
St Charles MO
St Charles MO
I did not, well, which is the left side of the car?
Also, I have been drivign mine 2 yrs this way and I figure they would have snapped by now if they were on the wrong side.....
1970 Coronet Vert
1972 Charger
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: torsion bar issues? [Re: 70Coronet500Vert] #68927
06/10/08 11:05 AM
06/10/08 11:05 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Drivers right,drivers left.
Re: torsion bar issues? [Re: stumpy] #68928
06/10/08 11:22 AM
06/10/08 11:22 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
huh?
Re: torsion bar issues? [Re: 05dakota] #68929
06/10/08 11:38 AM
06/10/08 11:38 AM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
As you sit in the car looking out windshield.
Left is drivers side, right passengers
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
Page 1 of 3 1 2 3
