Late model small block EFI in b-body #689037
05/05/10 01:40 AM
05/05/10 01:40 AM
Tyler, TX
LandShark Offline OP
Tyler, TX
Anyone running a late model EFI setup in a 60-70's car? If so, would you please post a picture? I have a 1997 magnum 360 and want to run fuel injection with a F.A.S.T. setup. I am anticipating hood clearance issues and would like to see what others have done...
Many Thanks
Re: Late model small block EFI in b-body [Re: LandShark] #689038
05/05/10 01:56 AM
05/05/10 01:56 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
This should probably be in QnA hardly a restoration question...
That said depending on body style the barrel intake will probably fit, fact is we put a 360 in a 70 RR clone using an airgrabber with the full oval aircleaner & everything fit fine...
Re: Late model small block EFI in b-body [Re: 1_WILD_RT] #689039
05/05/10 07:58 AM
05/05/10 07:58 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
board member andrewH has one in his '65 coronet, IIRC. hopefully he'll chime in
2017 Grand Cherokee Overland
Re: Late model small block EFI in b-body [Re: patrick] #689040
05/05/10 10:21 AM
05/05/10 10:21 AM
Andrewh Online content
Andrewh  Online Content
yep, running the 98 and up 5.9 in my car. 65 coronet vert.
Also have a topic on here somewhere on how to do it on the cheap using the mustang 5.0 efi system.
Fury Fan is doing all the work on it.
My post here fell off the board, but the one in the coronet board is still there.
http://www.dodgecoronet.com/forum/showthread.php?t=9664&highlight=magnum
Running the stock intake and painless controler.
The self tuning Fast system seemed intereesting and now you can get the carb intake for around 200 bucks it would probably be the easiest way, and one of the cheaper. But I figure it will still wind up in the 2k range when done.
Re: Late model small block EFI in b-body [Re: LandShark] #689041
05/05/10 12:18 PM
05/05/10 12:18 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
This will not cause you any clearance issues.
Re: Late model small block EFI in b-body [Re: Andrewh] #689042
05/08/10 01:09 AM
05/08/10 01:09 AM
Tyler, TX
Tyler, TX
Awesome pics and info... many thanks!
I was able to pick up an almost new F.A.S.T. efi setup for dirt cheap that was made specifically for the late model 5.9L. I am gonna run the carb with the serpentine setup for a short while and then go to the fuel injection...
Thanks again for the pics.
Re: Late model small block EFI in b-body [Re: LandShark] #689043
05/08/10 11:09 AM
05/08/10 11:09 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
better storke it if you want the car to move out. small block + B-body = S L O W.
Coming soon!!!!
Re: Late model small block EFI in b-body [Re: Mr.Yuck] #689044
05/08/10 12:56 PM
05/08/10 12:56 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
Stock stroke Small blocks are slow in B-bodies?? Man... I guess I'm hosed. I suppose it depends on your definition of "fast" huh?
A converter change and I should be "knocking" on 11's this year Gotta wait for the body shop to finish the work first though with my "heavier than a B-body" van.
That being said, I'm researching doing EFI in my van next year. Looks like Edelbrock EFI Manifold, Throttle body and injector rails (abour $900 for those), 8 x 880cc/min (83 lb/hr) injectors (not sure on $$ for those yet), dual walbro in tank 255 lph pumps (buying a new stock replacement tank to modify for this) (estimating $800-$1000 for fuel system), Accel Dual Sync DFI distributor (about $450), sensors and wiring and probably gonna try the Megasquirt 3 + MS3X for sequential EFI setup first (about $600 for that stuff). I figure between the fuel system and all other parts, she should come in around $3.5k for this setup, and be ready to support up to 1000 horsepower, far more than the current engine makes, but I like to overbuild things for future "upgradability" . I.E. addition of Turbo Charger and removal of Nitrous System.
Re: Late model small block EFI in b-body [Re: Alikazam] #689045
05/08/10 10:44 PM
05/08/10 10:44 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
not a chance you'll make a 1000hp on $3500. $ for $ ..and I love cool junk (6 packs, superchargers, turbos)... but a good soild BB will whomp SB especailly in a 65-72 B-body. I'll be running high 11's in a stock stroke .030 iron head 440 w/ a small solid cam. The truck did look nice and cool van! Dude had a SBC van running 12.80's at our track.
Coming soon!!!!
Re: Late model small block EFI in b-body [Re: Mr.Yuck] #689046
05/09/10 06:53 PM
05/09/10 06:53 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
The $3500 is for a 1000hp capable "fuel system" and EMS, not the entire setup. I'd be using the same small block I have now, and no turbos... yet. :P As for the BB whomping a SB, true more cubes = more power and generally more torque, but its all in how you do it and what you want I suppose. I like nitrous on my stock stroke 360 cuz its mild enough to drive daily (13.70 @ 99 on motor alone in my brick) and wild enough for bottom 12's with the turn of a valve and the flip of a switch I'm pretty sure though a 3800 lb B-Body with a 425 hp small block (like mine) would run awful close to high 12's, 13 flats. Again, depends on your definition of fast
There's a Chevy Van running 9's out there on a 400 sb + nitrous, fyi. It's on YouTube as well haha.
Re: Late model small block EFI in b-body [Re: Alikazam] #689047
05/09/10 07:23 PM
05/09/10 07:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
ahh support. cool enough. I like the van. got shag in it?
Re: Late model small block EFI in b-body [Re: Mr.Yuck] #689048
05/09/10 07:35 PM
05/09/10 07:35 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
Nope, but it does have carpet and padded walls She's currently being painted two tone with a tribal design separation line. :P
Re: Late model small block EFI in b-body [Re: Dragula] #689049
05/11/10 10:17 AM
05/11/10 10:17 AM
Columbia, Missouri
dtedler Offline
dtedler  Offline
Columbia, Missouri
What set-up is that - Is that the EZ-EFI? And where did you get those valve covers. I like 'em!
Re: Late model small block EFI in b-body [Re: dtedler] #689050
05/17/10 07:21 PM
05/17/10 07:21 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
bump for a good question Those are some nice valve covers It does look like the FAST EZ-EFI setup to me as well.
