E-body parking light turn signal questions
#687271
05/03/10 11:32 AM
05/03/10 11:32 AM
Posts: 1,417 Chicago, IL
blownEFI
Chicago, IL
Sorry for dumb sounding questions, but I don't have the car to look at right now.
On a 1970 Challenger there are two lights in the front valance panel with amber lenses. Do those serve as both the parking lights as well as the turn indicator lights?
How many filaments are in the bulbs for those front valance lights?
How many wires are in the pigtail for those front valance lights.
"These go to eleven", Nigel Tufnel
Re: E-body parking light turn signal questions
[Re: OzHemi]
#687273
05/03/10 12:07 PM
05/03/10 12:07 PM
blownEFI
Chicago, IL
Please check my logic on this.
The front valance lights are enclosed in a plastic housing, so there must be a ground wire in the pigtail right?
If the bulb has two filaments then there must be two supply wires in the pigtail right?
So that means the pigtail harness going into the front valance light has a total of three wires, is that right?
[Re: blownEFI]
#687274
05/03/10 12:19 PM
05/03/10 12:19 PM
Challenger 1
Cincinnati, Ohio
No, The front valance lights are grounded thru the housing, it's cast aluiminum. The plugs are color coded, one for the valance panel and one for the side markers. with single bullet connectors for the fender mounted turn lights being separate. All in the same wire harness.
[Re: Challenger 1]
#687275
05/03/10 12:38 PM
05/03/10 12:38 PM
blownEFI
Chicago, IL
Okay, check me again.
Front parking lights are grounded through the housing/valance, correct?
Front parking light bulbs contain two filaments, correct?
Wiring harness has three wires, two supply wires for the parking light and one for the side marker light, correct?
[Re: blownEFI]
#687276
05/03/10 01:29 PM
05/03/10 01:29 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Yes. Later E bodies had a plastic valence insert and had a seperate ground wire.
Yes
Correct but for the parking light on one filament, one for the turn signal.
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
