727 shifter seal, is it possible to change...
#686532
05/02/10 01:56 PM
05/02/10 01:56 PM
beedees
Re: 727 shifter seal, is it possible to change...
[Re: beedees]
#686533
05/02/10 02:02 PM
05/02/10 02:02 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
Yep. Valve body dropped down. Long bolt and nut and appropriately sized washers. Tighten the nut and bolt to draw the seal in. Actually pretty easy when i did it that way.
[Re: Pacnorthcuda]
#686536
05/02/10 02:19 PM
05/02/10 02:19 PM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
Yes, I have changed the seal in my Challenger with headers.
Did NOT remove anything, poped the seal out with a screw driver going in at an angle and taped the new one in with a small hammer
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: BDW]
#686542
05/02/10 11:20 PM
05/02/10 11:20 PM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
I did it in car, pan and VB in place, using a cheaper version of the KD tools package there. (At least, it was cheaper than the KD tools I could have bought at the time). http://www.toolskwik.com/StoreFrontProfi...amp;i=234494994Didn't use a c-clamp to install it, but made a hole in the floor to allow access to hammer it down. I had made holes all over the car, and had no carpet, so didn't hesitate to drill a hole..
Post deleted by Defbob
[Re: 65Valiant]
#686544
05/03/10 02:54 AM
05/03/10 02:54 AM
