727 shifter seal, is it possible to change... #686532
05/02/10 01:56 PM
05/02/10 01:56 PM
beedees Offline OP
beedees  Offline OP
...while still in the car? 1967 Coronet R/T BTW. Anybody have any tips or pointers? Any and all info appreciated. Thanks
Re: 727 shifter seal, is it possible to change... [Re: beedees] #686533
05/02/10 02:02 PM
05/02/10 02:02 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Yep. Valve body dropped down. Long bolt and nut and appropriately sized washers. Tighten the nut and bolt to draw the seal in. Actually pretty easy when i did it that way.
Re: 727 shifter seal, is it possible to change... [Re: forphorty] #686534
05/02/10 02:09 PM
05/02/10 02:09 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I used 3/8 threaded rod on my old truck!
Re: 727 shifter seal, is it possible to change... [Re: forphorty] #686535
05/02/10 02:11 PM
05/02/10 02:11 PM
Kirkland, Washington
Pacnorthcuda Offline
It is easy with the VB out. I've done it without even dropping the tranny pan on a 77 Volare though. Its tough, but less work (if that makes sense)
Pry the old sealup off the shaft. Dress the shaft with sandpaper/crocus, clean, install new seal by careful use of c-clamp. Very little room to work in.
Re: 727 shifter seal, is it possible to change... [Re: Pacnorthcuda] #686536
05/02/10 02:19 PM
05/02/10 02:19 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Yes, I have changed the seal in my Challenger with headers.
Did NOT remove anything, poped the seal out with a screw driver going in at an angle and taped the new one in with a small hammer
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: 727 shifter seal, is it possible to change... [Re: beedees] #686537
05/02/10 02:22 PM
05/02/10 02:22 PM
beedees Offline OP
beedees  Offline OP
Thanks for the info. If I need to r&r the VB, anything I need to watch out for? Been about twenty years since I've done anything like this.
I should have asked, is the ATF level that high in the trans.? Leaks just sitting, cleaned everything off and it took about four days for the fluid to show up on the floor. It is coming from around the area of the shifter stem, though.
Re: 727 shifter seal, is it possible to change... [Re: forphorty] #686538
05/02/10 06:01 PM
05/02/10 06:01 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
done myself on same way LOONG time ago, and will be on that again pretty soon, since the pan gasket looks something weird too.
If wasn't because the pan gasket replacement, I think the C lamp and socket looks a good idea too.
Re: 727 shifter seal, is it possible to change... [Re: NachoRT74] #686539
05/02/10 06:18 PM
05/02/10 06:18 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
BE SURE to clean-up the VB shaft itself. In most cases the shaft is corroded or rusty and if you do not properly prep the shaft .. it will just chew-up the new seal.
Re: 727 shifter seal, is it possible to change... [Re: dOc !] #686540
05/02/10 08:28 PM
05/02/10 08:28 PM
scratchnfotraction Offline
clean with brake clean,throw a ahnd full of baby powder around the shift lever area,it will pin point the leak
like said,prep the shaft for the new seal,dont roll the lip of the seal putting the VB back in either
yes fluid is that high and will leak sitting
Re: 727 shifter seal, is it possible to change... [Re: scratchnfotraction] #686541
05/02/10 08:49 PM
05/02/10 08:49 PM
BDW Online content
BDW  Online Content
Here's what I did
Re: 727 shifter seal, is it possible to change... [Re: BDW] #686542
05/02/10 11:20 PM
05/02/10 11:20 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I did it in car, pan and VB in place, using a cheaper version of the KD tools package there. (At least, it was cheaper than the KD tools I could have bought at the time).
http://www.toolskwik.com/StoreFrontProfi...amp;i=234494994
Didn't use a c-clamp to install it, but made a hole in the floor to allow access to hammer it down. I had made holes all over the car, and had no carpet, so didn't hesitate to drill a hole..
Re: 727 shifter seal, is it possible to change... [Re: Exit1965] #686543
05/03/10 02:12 AM
05/03/10 02:12 AM
65Valiant Offline
super street
65Valiant  Offline
super street
Ive got that tool i can sell to you- It wouldn't fit in my 65 valiant so I never go to use it.
Ill ship for cheap too!
let me know
Post deleted by Defbob [Re: 65Valiant] #686544
05/03/10 02:54 AM
05/03/10 02:54 AM
Re: 727 shifter seal, is it possible to change... #686545
05/03/10 03:37 AM
05/03/10 03:37 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
I did my '70 Barracuda in place with this little tool I made
The split ring is just a spring fit, it holds the seal central with the hole while I screw the bolt from the bottom then just slides off the top as the seal pulls in.
