wheel backspacing on b-body #683873
04/29/10 08:51 PM
04/29/10 08:51 PM
Owosso, Michigan
stateroadhog Offline OP
Owosso, Michigan
I want to have my steel wheels widein to 8 inches on the rear of my 70 roadrunner with dana rear end. what should the back spacing be set at?
Re: wheel backspacing on b-body [Re: stateroadhog] #683874
04/29/10 09:00 PM
04/29/10 09:00 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Typically, for a 8" wheel, a squared up backspace would be about 4-3/4" (factory steel 7" wheels are @ 4-1/4") A 70 should have no problem fitting just about anything that will fit on a wheel in that neighborhood.
Re: wheel backspacing on b-body [Re: stateroadhog] #683875
04/30/10 02:01 AM
04/30/10 02:01 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Why not take the wheels out to 10 inch? I fit 18x10 rims in my 70 Charger without cutting anything. They have 4 3/4 inch backspacing.
Re: wheel backspacing on b-body [Re: Kern Dog] #683876
04/30/10 10:59 AM
04/30/10 10:59 AM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Passenger tire size choices are lacking for a 15X10 wheel if you don't want drag radials. You are stuck with 295/50R15 tires and those are less than 27" tall.
Btw, Don't square those 8" wheels in the wheel well. Put all the extra width on the front side of the wheel and fill in some of that gap.... will look much better. So 4.25 bs in that case.
I had some 8.5" wheels on the back of my '70 Bee that had a 3.75" bs and they looked quite nice (going to 10" now though).
Re: wheel backspacing on b-body [Re: PAINT IT BLACK] #683877
04/30/10 11:12 AM
04/30/10 11:12 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Mickey Thompson makes Sportsman SR street radials in 28 x 12 x 15.
Hoosier makes Pro Street radials in 29 x 12.50 x 15.
Both tires fit 10" wheels nicely.
Re: wheel backspacing on b-body [Re: stateroadhog] #683878
04/30/10 11:40 AM
04/30/10 11:40 AM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Re: wheel backspacing on b-body [Re: stateroadhog] #683879
04/30/10 12:38 PM
04/30/10 12:38 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
What size tire are you planing to use?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: wheel backspacing on b-body [Re: stateroadhog] #683880
04/30/10 12:56 PM
04/30/10 12:56 PM
AndyF Online content
AndyF  Online Content
You might be able to find someone in the local area who has a tape measure who could help you measure the wheel wells. That is the best way to figure out how wide the wheels can be and where they should be centered.
Re: wheel backspacing on b-body [Re: AndyF] #683881
04/30/10 07:42 PM
04/30/10 07:42 PM
NJ
440challenger Offline
NJ
probably cheaper just to buy new 8inch wheel vintiques 4.5 inch bs
Re: wheel backspacing on b-body [Re: 440challenger] #683882
05/01/10 02:31 AM
05/01/10 02:31 AM
So Cal
So Cal
The only problem with wheel vintiques is, they are really heavy
Re: wheel backspacing on b-body [Re: HealthServices] #683883
05/01/10 03:18 AM
05/01/10 03:18 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Heavy? So what? The mopar engines make plenty of torque anyway.
The Heavier wheels wont make that much difference in acceleration, but they will allow a factory appearance and they are strong.
Re: wheel backspacing on b-body [Re: HealthServices] #683884
05/01/10 07:56 PM
05/01/10 07:56 PM
Wheel Vintiques 15X8'S = 27 lbs. apiece.
