Re: wheel backspacing on b-body
[Re: stateroadhog]
#683874
04/29/10 09:00 PM
04/29/10 09:00 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Typically, for a 8" wheel, a squared up backspace would be about 4-3/4" (factory steel 7" wheels are @ 4-1/4") A 70 should have no problem fitting just about anything that will fit on a wheel in that neighborhood.
[Re: Kern Dog]
#683876
04/30/10 10:59 AM
04/30/10 10:59 AM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
Why not take the wheels out to 10 inch? I fit 18x10 rims in my 70 Charger without cutting anything. They have 4 3/4 inch backspacing.
Passenger tire size choices are lacking for a 15X10 wheel if you don't want drag radials. You are stuck with 295/50R15 tires and those are less than 27" tall.
Btw, Don't square those 8" wheels in the wheel well. Put all the extra width on the front side of the wheel and fill in some of that gap.... will look much better. So 4.25 bs in that case.
I had some 8.5" wheels on the back of my '70 Bee that had a 3.75" bs and they looked quite nice (going to 10" now though).
[Re: stateroadhog]
#683879
04/30/10 12:38 PM
04/30/10 12:38 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
What size tire are you planing to use?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: 440challenger]
#683882
05/01/10 02:31 AM
05/01/10 02:31 AM
Posts: 7,759 So Cal
HealthServices
So Cal
The only problem with wheel vintiques is, they are really heavy
Allen
[Re: HealthServices]
#683884
05/01/10 07:56 PM
05/01/10 07:56 PM
Wheel Vintiques 15X8'S = 27 lbs. apiece.
