Roller Cam 360 Differences? #682622
04/28/10 01:47 PM
04/28/10 01:47 PM
St.Clairsville Ohio
EV2RUNNER Offline OP
St.Clairsville Ohio
Im wanting to convert a 92 360 back to pre roller style lifters and pushrods. Are the lifters, pushrods and cam the only thing that changed? I was hoping I could just change out the Lifters and pushrods and be able to run a regular LA aftermarket cam..Am I correct? I know I could have a cam reground to fit the roller setup but I wanna go Old style LA.. Thanks
Re: Roller Cam 360 Differences? [Re: EV2RUNNER] #682623
04/28/10 02:05 PM
04/28/10 02:05 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
As I understand it, the only differences are more clearance for the roller lifters in the magnum block casting and a passage to pump oil into the valve lifter gallery.
I went the opposite direction going with a Magnum block with roller lifters for my 73.
Craig
Re: Roller Cam 360 Differences? [Re: denfireguy] #682624
04/28/10 02:29 PM
04/28/10 02:29 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Craig
the '92 is an LA...the lifter bores of a roller cam block are slightly taller. the holes in the head the pushrods go through are slightly larger, due to the different pushrod angle with the longer roller lifter/shorter pushrods combo.
other than that, a flat tappet with the proper pushrods will drop right in. the question is, why? you can reuse your existing roller lifters, and most likely your pushrods with a new or reground roller cam. that puts it in the price of $150 (reground)-$300 (new). by the time you buy a decent cam/lifter combo (comp XE or lunati voodoo) you're looking at $180-200, plus new pushrods ($30-100), so you're not saving any money, and you have the potential worry/headache of a cam lobe going flat.
2017 Grand Cherokee Overland
Re: Roller Cam 360 Differences? [Re: patrick] #682625
04/28/10 04:05 PM
04/28/10 04:05 PM
St.Clairsville Ohio
St.Clairsville Ohio
Basicly, it all boils down to time... I need to have the motor built, in and running by the end of next month. Ive already got most of the parts here, the rest are in stock at summit. I dont wanna take a chance of going with a reground cam and not having it back in time.
Re: Roller Cam 360 Differences? [Re: patrick] #682626
04/28/10 04:07 PM
04/28/10 04:07 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
you should trade me blocks...
I am truckless..
Re: Roller Cam 360 Differences? [Re: 340SHORTY] #682627
04/28/10 04:20 PM
04/28/10 04:20 PM
St.Clairsville Ohio
St.Clairsville Ohio
If you were closer.... BUT If you wanna come get it bring me one of those no rust 70s PowerWagons I always see on ebay for dirt cheap up your way!
Re: Roller Cam 360 Differences? [Re: EV2RUNNER] #682628
04/28/10 04:34 PM
04/28/10 04:34 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
hughes sells them on an exchange basis....
turnaround when I had Bullet Cams do mine was exactly 1 week, but I paid a little extra for 2 day guaranteed shipping both ways.
