Truck Dana 60 #679691
04/25/10 08:37 AM
04/25/10 08:37 AM
Pittsfield, Mass.
Russ_Davis Offline OP
Pittsfield, Mass.
I have a dana 60 from a Ford 3/4 ton. Is it worth it to change it to a car rear, and what needs to be done?
Re: Truck Dana 60 [Re: Russ_Davis] #679692
04/25/10 10:18 AM
04/25/10 10:18 AM
AndyF Offline
AndyF  Offline
Probably costs about the same by the time you're all done unless you do the work yourself. At the minimum you'll need new axles, brakes and housing ends.
Re: Truck Dana 60 [Re: AndyF] #679693
04/25/10 12:35 PM
04/25/10 12:35 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
and the truck ones weigh a ton
Re: Truck Dana 60 [Re: Russ_Davis] #679694
04/25/10 07:35 PM
04/25/10 07:35 PM
florida
74fldart Offline
74fldart  Offline
florida
i did the same thing 2 yrs back and i have around $1500.00 in mine. the truck is probably a full floater so the axles, bearing housing ends, brakes , etc. wont be good for the car.
is it worth it? , maybe if your racing it and need the strength of the dana.
Re: Truck Dana 60 [Re: prochargedhemi] #679695
04/25/10 08:20 PM
04/25/10 08:20 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
With parts I bought from doctor diff, I narrowed my own.
Quite a bit cheaper than buying one built IMHO. Especially if you luck out,a nd it has the gears that you want, in usable shape.
As for the weight, I had mine next to a oem dana car housing. They were identical. Only the HD 60 housing is noticably heavier. When you cut down a regular truck d60 you cut most of the heavy stuff off.
Re: Truck Dana 60 [Re: dave571] #679696
04/25/10 08:35 PM
04/25/10 08:35 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Ok saying the guts are good with the sure grip how do you get to $1500. Most yards around here want $150-200. The ends are $75 My guy charges $150 to narrow and weld in perches. I have a ton of brakes and drums. Lets say you have an 8 3/4 you can use the brakes off the 8 3/4 on the dana.
So you should be at $850 or less depending on the purchase price and narrowing cost. There's alot of ground to be made up there. If you did it and you are over $1000 where did the extra cash go?
Re: Truck Dana 60 [Re: Russ_Davis] #679697
04/25/10 09:03 PM
04/25/10 09:03 PM
$202 for the housing
$65-70 approx shipping
$250 for narrowing
$101 for the ends
$760 for the willwood disc brake kit
$400 approx for the axles
$600 Detroit locker
$ ? bearings
$ ? assembley
$280 gears
________________
$2665
Probably around $3000- 3200 when done. I took the perches off because ladder bars are being used but all in all still cheaper than buying new and having it shipped plus duties.
Re: Truck Dana 60 [Re: ] #679698
04/25/10 09:28 PM
04/25/10 09:28 PM
N
NITROUSN Offline
NITROUSN  Offline
N
$250 for narrowing
$101 for the ends
$600 Detroit locker
$ ? bearings
$ ? assembley
$280 gears
________________
$2665
You can get a brand spankin new one from Doc D for about the same.
Re: Truck Dana 60 [Re: NITROUSN] #679699
04/25/10 09:44 PM
04/25/10 09:44 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I had less than $1K in my Truck Dana including the disc brake conversion. I picked up the spool, ring and pinion used..everything else is new. New axles, new bearings. I narrowed it my self and made the disc brake setup my self...
All it takes is a welded and a grinder and some imagination..
and some fabing skills doesnt hurt either.
Re: Truck Dana 60 [Re: Bob_Coomer] #679700
04/25/10 09:55 PM
04/25/10 09:55 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
All it takes is shopping for deals and you can definitely build one cheap.
If you shop for deals from swap meets and even ebag they're out there.
I picked up a brand new set of Dana 60 Richmond 4.10 gears and new complete bearing set for $150.
I got a new Dana 60 35 spline power lock for $300 off ebag.
Deals are out there, just takes a little patience and grabbing the deal when it shows up.
