Re: Truck Dana 60
[Re: prochargedhemi]
#679695
04/25/10 08:20 PM
04/25/10 08:20 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
With parts I bought from doctor diff, I narrowed my own.
Quite a bit cheaper than buying one built IMHO. Especially if you luck out,a nd it has the gears that you want, in usable shape.
As for the weight, I had mine next to a oem dana car housing. They were identical. Only the HD 60 housing is noticably heavier. When you cut down a regular truck d60 you cut most of the heavy stuff off.
Re: Truck Dana 60
[Re: dave571]
#679696
04/25/10 08:35 PM
04/25/10 08:35 PM
moparpollack
Lil Herman
Lil Herman
85086
Ok saying the guts are good with the sure grip how do you get to $1500. Most yards around here want $150-200. The ends are $75 My guy charges $150 to narrow and weld in perches. I have a ton of brakes and drums. Lets say you have an 8 3/4 you can use the brakes off the 8 3/4 on the dana. So you should be at $850 or less depending on the purchase price and narrowing cost. There's alot of ground to be made up there. If you did it and you are over $1000 where did the extra cash go?
Re: Truck Dana 60
[Re: Russ_Davis]
#679697
04/25/10 09:03 PM
04/25/10 09:03 PM
$202 for the housing $65-70 approx shipping $250 for narrowing $101 for the ends $760 for the willwood disc brake kit $400 approx for the axles $600 Detroit locker $ ? bearings $ ? assembley $280 gears ________________ $2665 Probably around $3000- 3200 when done. I took the perches off because ladder bars are being used but all in all still cheaper than buying new and having it shipped plus duties.
Re: Truck Dana 60
[Re: ]
#679698
04/25/10 09:28 PM
04/25/10 09:28 PM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
You can get a brand spankin new one from Doc D for about the same.
Re: Truck Dana 60
[Re: NITROUSN]
#679699
04/25/10 09:44 PM
04/25/10 09:44 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I had less than $1K in my Truck Dana including the disc brake conversion. I picked up the spool, ring and pinion used..everything else is new. New axles, new bearings. I narrowed it my self and made the disc brake setup my self... All it takes is a welded and a grinder and some imagination.. and some fabing skills doesnt hurt either.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
