440 Jet Boat Anyone ran or running one? #674149
04/18/10 09:54 PM
04/18/10 09:54 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
I picked up a 17 1/2 foot jet boat last fall been working on it needing some help on the cooling system anyone?
Brian
Re: 440 Jet Boat Anyone ran or running one? [Re: Bishop] #674150
04/19/10 09:13 AM
04/19/10 09:13 AM
United States
V
v269 Offline
v269  Offline
V
United States
Re: 440 Jet Boat Anyone ran or running one? [Re: v269] #674151
04/19/10 11:27 AM
04/19/10 11:27 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
http://www.socaljetboats.com/engine-mech...266a975a03f906a
Now IF they would have a specific V-drive forum !!
I am putting my boat together slowly ... and I have decided to run a "closed" cooling system. Reason ? .. because when using lake water - most applications NEVER get-up to good operating temp.
Re: 440 Jet Boat Anyone ran or running one? [Re: Bishop] #674152
04/19/10 11:30 AM
04/19/10 11:30 AM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
Brian
Did you get my pics over on Performance boats?
Re: 440 Jet Boat Anyone ran or running one? [Re: BB70DUSTER] #674153
04/19/10 01:09 PM
04/19/10 01:09 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
Try www.screamandfly.com
They have forums and tech sections.
Nice boat!
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: 440 Jet Boat Anyone ran or running one? [Re: Bishop] #674154
04/19/10 02:32 PM
04/19/10 02:32 PM
United States
V
v269 Offline
v269  Offline
V
United States
Re: 440 Jet Boat Anyone ran or running one? [Re: v269] #674155
04/19/10 03:11 PM
04/19/10 03:11 PM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
I think what he was getting at, is the fact that a 440 does not have a water outlet on the intake, its on the water pump... Which a jet boat does not use....
Re: 440 Jet Boat Anyone ran or running one? [Re: Bishop] #674156
04/19/10 03:33 PM
04/19/10 03:33 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
The beauty of the B/RB wedge for jet boat is you can use the front cooling ports for inlet/outlet or the lower block drain plugs as an outlet. Outfitting a T-stat is a bigger problem. There's ways to fab up a housing using a Brand-C marine T-stat housing.
If you really want to run an "enclosed system", simply learn how to use a TIG welder and make your own aluminum radiators then mount them into the side gunnels, w/remote elec. fans, or one big rad. mounted in back. Either way it's a fab all deal.
My 18' jet runs the coolant in through the front lower cooling passages and out the uppers. It has an old Edelbrock marine set-up. The key ingredient is to monitor your system pressure. With a closed system, an aftermarket electric pump (Mezuirre sp?) like the drag racers use might be the way to go. Jetters typically use a pressure by-pass regulator since pump pressure can get as high as 200-300 psi.
V-drives rule but jets are far more cost effective and easier to maintain.
Re: 440 Jet Boat Anyone ran or running one? [Re: Dean_Kuzluzski] #674157
04/19/10 10:52 PM
04/19/10 10:52 PM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
Uhhhh... yeh.... if you say so....
Re: 440 Jet Boat Anyone ran or running one? [Re: BB70DUSTER] #674158
04/19/10 11:07 PM
04/19/10 11:07 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
WHICH part of this quote do you have a prob with ?
Re: 440 Jet Boat Anyone ran or running one? [Re: dOc !] #674159
04/19/10 11:12 PM
04/19/10 11:12 PM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
Maybe back east where you guys are, V drives rule... not so much out here... nothing cheap about putting HP to a Jet either...
Re: 440 Jet Boat Anyone ran or running one? [Re: BB70DUSTER] #674160
04/19/10 11:19 PM
04/19/10 11:19 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
I am hardly an expert ... I am still working on my v-drive project ... but I have a 17' Hydrostream with a Black Max if I have the need-ferr-speed on-da-water ....
But I agree that V-drives "rule" ... BIG TIME .. if everything else is equal ...
But cheaper and EZier to maintain ? ... how is that figured ?
Re: 440 Jet Boat Anyone ran or running one? [Re: dOc !] #674161
04/20/10 12:01 AM
04/20/10 12:01 AM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
theres plenty of triple digit jets out there is all Im sayin... Not to mention having a better ride in a tunnel or gull wing...
Re: 440 Jet Boat Anyone ran or running one? [Re: BB70DUSTER] #674162
04/20/10 01:12 AM
04/20/10 01:12 AM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
I'll second that, here in central cali on the Kings River between Reedley and Kingsburg a V-drive is pretty rare. The river is shallow, but....it's better than any lake for skiing. Your intended environment should also play a part in the decision between the two.
Re: 440 Jet Boat Anyone ran or running one? [Re: BB70DUSTER] #674163
04/20/10 08:17 AM
04/20/10 08:17 AM
Holly/MI
Holly/MI
Call me crazy, but a pump just isn't as efficient as a prop. I'm not trying to stir up anyfight here I own one of each and appreciate them both for what they are. BUT, given the same level of HP and a similar length, beam width of the hull the v-drive is worth 5-10 mph more. Yep, there's lots of fast jetters out there, way faster than me, but it's just an opinion, an observation over the years.
Re: 440 Jet Boat Anyone ran or running one? [Re: Dean_Kuzluzski] #674164
04/20/10 08:23 AM
04/20/10 08:23 AM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
Ok, I'll post a second question here. For a V-drive, 440 or 383?
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: 440 Jet Boat Anyone ran or running one? [Re: maundmotorworks] #674165
04/20/10 09:43 AM
04/20/10 09:43 AM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
My opinion is bigger is always better....
Re: 440 Jet Boat Anyone ran or running one? [Re: Dean_Kuzluzski] #674166
04/20/10 09:46 AM
04/20/10 09:46 AM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
Its no secret a prop is more efficient, I just dont agree that a V-Drive rules... this is my last jet...
Re: 440 Jet Boat Anyone ran or running one? [Re: BB70DUSTER] #674167
04/20/10 10:19 AM
04/20/10 10:19 AM
Holly/MI
Holly/MI
Your opinion is noted.
I like jets due to the simplicity of design. A simple rack-n-pinion/cable combo for steering, a reverse bucket for backing up and far less bushings, bearings, gears, seals and gaskets to add to the cost when freshening the driveline. This I know for sure. Not to mention the initial cost to begin with.
Re: 440 Jet Boat Anyone ran or running one? [Re: maundmotorworks] #674168
04/20/10 11:04 AM
04/20/10 11:04 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
MY CHOICE is a hi-compression 383 ... since there is no transmission(and only ONE speed) .... I choose RPM abilities.
