440 Jet Boat Anyone ran or running one?
#674149
04/18/10 09:54 PM
04/18/10 09:54 PM
Posts: 915 Cincinnati OH
Bishop
Cincinnati OH
I picked up a 17 1/2 foot jet boat last fall been working on it needing some help on the cooling system anyone?
Brian
Re: 440 Jet Boat Anyone ran or running one?
[Re: Bishop]
#674152
04/19/10 11:30 AM
04/19/10 11:30 AM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
Brian
Did you get my pics over on Performance boats?
[Re: BB70DUSTER]
#674153
04/19/10 01:09 PM
04/19/10 01:09 PM
Posts: 5,270 Missouri
MY340
Missouri
Try www.screamandfly.comThey have forums and tech sections. Nice boat!
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
[Re: Bishop]
#674156
04/19/10 03:33 PM
04/19/10 03:33 PM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
The beauty of the B/RB wedge for jet boat is you can use the front cooling ports for inlet/outlet or the lower block drain plugs as an outlet. Outfitting a T-stat is a bigger problem. There's ways to fab up a housing using a Brand-C marine T-stat housing.
If you really want to run an "enclosed system", simply learn how to use a TIG welder and make your own aluminum radiators then mount them into the side gunnels, w/remote elec. fans, or one big rad. mounted in back. Either way it's a fab all deal.
My 18' jet runs the coolant in through the front lower cooling passages and out the uppers. It has an old Edelbrock marine set-up. The key ingredient is to monitor your system pressure. With a closed system, an aftermarket electric pump (Mezuirre sp?) like the drag racers use might be the way to go. Jetters typically use a pressure by-pass regulator since pump pressure can get as high as 200-300 psi.
V-drives rule but jets are far more cost effective and easier to maintain.
[Re: Dean_Kuzluzski]
#674157
04/19/10 10:52 PM
04/19/10 10:52 PM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
Uhhhh... yeh.... if you say so....
[Re: BB70DUSTER]
#674158
04/19/10 11:07 PM
04/19/10 11:07 PM
Posts: 30,430 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
WHICH part of this quote do you have a prob with ?
[Re: BB70DUSTER]
#674162
04/20/10 01:12 AM
04/20/10 01:12 AM
Posts: 5,135 Kingsburg Calif.
Quikshft
Kingsburg Calif.
Maybe back east where you guys are, V drives rule... not so much out here... nothing cheap about putting HP to a Jet either...
I'll second that, here in central cali on the Kings River between Reedley and Kingsburg a V-drive is pretty rare. The river is shallow, but....it's better than any lake for skiing. Your intended environment should also play a part in the decision between the two.
[Re: maundmotorworks]
#674165
04/20/10 09:43 AM
04/20/10 09:43 AM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
Ok, I'll post a second question here. For a V-drive, 440 or 383?
My opinion is bigger is always better....
#674166
04/20/10 09:46 AM
04/20/10 09:46 AM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
Call me crazy, but a pump just isn't as efficient as a prop. I'm not trying to stir up anyfight here I own one of each and appreciate them both for what they are. BUT, given the same level of HP and a similar length, beam width of the hull the v-drive is worth 5-10 mph more. Yep, there's lots of fast jetters out there, way faster than me, but it's just an opinion, an observation over the years.
Its no secret a prop is more efficient, I just dont agree that a V-Drive rules... this is my last jet...
#674168
04/20/10 11:04 AM
04/20/10 11:04 AM
BeEtLeJuIcE !
Florida STAYcation
MY CHOICE is a hi-compression 383 ... since there is no transmission(and only ONE speed) .... I choose RPM abilities.
