installing new dash wiring harness, need help!
#672259
04/17/10 01:10 AM
04/17/10 01:10 AM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
I am replacing the dash harness on my 71 scamp due to a electrical oops that burned the old one. I was smart and took pictures of every connection and named them! then that computer died. @#$!@#$ %^$%&^ Anyways..
I have it all almost figured out except for these two connectors where I can't remember where they went. The pictures are from the connectors on the old harness so its easier to see.
#1, this comes off the harness after the wiper switch connections and is kinda behind the ashtray area.
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
Re: installing new dash wiring harness, need help!
[Re: blown340]
#672260
04/17/10 01:13 AM
04/17/10 01:13 AM
blown340
Walnut Creek, CA
Here is the second one I can't remember where it goes. Its also back by the ashtray area and comes downstream on the wiring harness from the first connector shown.
[Re: blown340]
#672261
04/17/10 01:15 AM
04/17/10 01:15 AM
blown340
Walnut Creek, CA
Thanks for any and all help! Just for reference the car is a 71 plymouth valiant scamp. It was originally a 318 auto car with factory A/C that my grandma bought new and I've had for 16 years now. It is stock except for a swap from the A904 to a A833OD and a updgrade to a modern A/C compressor/refrigerent. Thanks!!!! -Jon
[Re: 340dart4spd ]
#672263
04/17/10 01:28 AM
04/17/10 01:28 AM
blown340
Walnut Creek, CA
1st pic poss radio plug
2nd pic looks like heater box fan to me
Thanks for the quick reply! the first one isn't the radio plug. The other plug in the first pic goes into the radio.
I'll double check and see if there is any place on the HVAC stuff where the 2nd one could plug in. So far I haven't seen it, but that doesn't mean much.
Thanks again, -Jon
[Re: 340dart4spd ]
#672265
04/17/10 01:43 AM
04/17/10 01:43 AM
blown340
Walnut Creek, CA
HV/AC box should plug into top of box
Is there another one other than this that I'm missing? If so, where is it located? Thanks!!!!!!
[Re: blown340]
#672266
04/17/10 01:52 AM
04/17/10 01:52 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
It seems to me that the yellow wires were al dome light circuit stuff... glove box light, map light, trunk light, ignition light, that kind of stuff.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#672267
04/17/10 03:51 PM
04/17/10 03:51 PM
blown340
Walnut Creek, CA
[Re: blown340]
#672268
04/17/10 05:37 PM
04/17/10 05:37 PM
Posts: 341 New Jersey
U_Code_Cuda
New Jersey
Just did my Dash Harness on my 71 Demon and the first pic is the connector to the Heater controls...My harness had the 3rd wire(black) seperate but, I plugged it into the 3rd connector opening on that plug as my old harness had it like that......
1970 R/T Challenger 4-speed 1971 Demon 340 3-speed
