installing new dash wiring harness, need help! #672259
04/17/10 01:10 AM
04/17/10 01:10 AM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
I am replacing the dash harness on my 71 scamp due to a electrical oops that burned the old one. I was smart and took pictures of every connection and named them! then that computer died. @#$!@#$ %^$%&^ Anyways..
I have it all almost figured out except for these two connectors where I can't remember where they went. The pictures are from the connectors on the old harness so its easier to see.
#1, this comes off the harness after the wiper switch connections and is kinda behind the ashtray area.
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: installing new dash wiring harness, need help! [Re: blown340] #672260
04/17/10 01:13 AM
04/17/10 01:13 AM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Here is the second one I can't remember where it goes. Its also back by the ashtray area and comes downstream on the wiring harness from the first connector shown.
Re: installing new dash wiring harness, need help! [Re: blown340] #672261
04/17/10 01:15 AM
04/17/10 01:15 AM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Thanks for any and all help! Just for reference the car is a 71 plymouth valiant scamp. It was originally a 318 auto car with factory A/C that my grandma bought new and I've had for 16 years now. It is stock except for a swap from the A904 to a A833OD and a updgrade to a modern A/C compressor/refrigerent.
Thanks!!!!
-Jon
Re: installing new dash wiring harness, need help! [Re: blown340] #672262
04/17/10 01:17 AM
04/17/10 01:17 AM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
1st pic poss radio plug
2nd pic looks like heater box fan to me
Re: installing new dash wiring harness, need help! [Re: 340dart4spd ] #672263
04/17/10 01:28 AM
04/17/10 01:28 AM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Thanks for the quick reply! the first one isn't the radio plug. The other plug in the first pic goes into the radio.
I'll double check and see if there is any place on the HVAC stuff where the 2nd one could plug in. So far I haven't seen it, but that doesn't mean much.
Thanks again,
-Jon
Re: installing new dash wiring harness, need help! [Re: blown340] #672264
04/17/10 01:36 AM
04/17/10 01:36 AM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
HV/AC box should plug into top of box
Re: installing new dash wiring harness, need help! [Re: 340dart4spd ] #672265
04/17/10 01:43 AM
04/17/10 01:43 AM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Is there another one other than this that I'm missing? If so, where is it located? Thanks!!!!!!
Re: installing new dash wiring harness, need help! [Re: blown340] #672266
04/17/10 01:52 AM
04/17/10 01:52 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
It seems to me that the yellow wires were al dome light circuit stuff... glove box light, map light, trunk light, ignition light, that kind of stuff.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: installing new dash wiring harness, need help! [Re: HealthServices] #672267
04/17/10 03:51 PM
04/17/10 03:51 PM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Re: installing new dash wiring harness, need help! [Re: blown340] #672268
04/17/10 05:37 PM
04/17/10 05:37 PM
New Jersey
U_Code_Cuda Offline
U_Code_Cuda  Offline
New Jersey
Just did my Dash Harness on my 71 Demon and the first pic is the connector to the Heater controls...My harness had the 3rd wire(black) seperate but, I plugged it into the 3rd connector opening on that plug as my old harness had it like that......
1970 R/T Challenger 4-speed
1971 Demon 340 3-speed
